Banned
I'm just starting a rebuild of an older Bryston 3B.
I got it for $30, apparently it had a bad channel. For the price I figured it was worth a shot, I could always use it for parts. Before I tore it down I thought I would try it first, I did get sound out of both channels if I played with the power switch. So it looks like I might be in luck. It's filthy and a little worn, it is well used. I would imagine it has been used everyday since it was new. So I figure I will have at it, the problems might go away with a good cleaning. I am going to re-cap the power supply, although I might use it for a bit with the old caps against my better judgement. Anybody done any "upgrades" to their Bryston? |
#2 |
Electrolytics have the shortest life in an amp so they will need looking at first.
I would also clean out any fluff and dust to stop the amp overheating.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Banned
Yes it is dirty. It takes multiple steps to get it clean. Goo-gone and then TSP. Sometimes I have to repeat the process.
OK so I checked the capacitors for fun. They read a little low, but seem to be functional. My capacitor checker is the low voltage type. (BK precision 820), so I don't have a whole lot of faith in the test. Now the filter caps are 7500uf+7500uf 50v in series for each channel. This gives ~3500uf @100v. I wonder the reasoning for this? Simply to raise the voltage rating of available caps? I guess I could just replace the 7500uf + 7500uf 50v's with a single 3500mf cap at 100V? (If available) Not that I needs it, but maybe I could increase the capacitance while I'm at it. |
#4 |
High voltage large capacitors are expensive and more rare.
I wouldnt increase the capacitance too much or you might get switch on surge problems like fuses blowing. Perhaps 4700uf 100v as they are quite common.
#5 |
Banned
I just had a peek online.
Going with a 4700uf /100V looks like the way to go, there is lot's to choose from, I only saw one 7500uf so far. Good to have some options. There is also some 3500uf 400v computer type caps that might be an option too. |
#6 |
Bryston are very good amps. I would send it back to Bryston for a full check up. the service is excellent.
#7 |
Banned
I thought about looking into that. I am pretty sure it's older then 20 years though.
Either way. |
#8 | |
" hey and they are located near you lol." |
#9 |
Banned
Sorry Lanchile, looks like I'm going the DIY route! You are right though.
I actually might see if I could get my own tour there one day, would make for an awesome road trip. So I finally got the thing cleaned up. It sure was a lot of work. I have cleaned every part except the actual circuit boards. I will do them separately. I fought in -20 weather inside of an improvised paint tent to get my polyeurea coating on. Barely got it done with out screwing it up. lol. Here's a picture of the assembly started. I installed some new feet. If those Hammond transformers don't give you a hard-on there's something wrong with you. |
#10 | |
PS: I had a Bryston B60 before, but I sold it and went for a diy integrated amp. Happy as a clam!!! Last edited by lanchile; 17th January 2012 at 12:51 AM. |
| bryston 3B | bigcat | Solid State | 3 | 13th January 2012 04:30 PM |
| Bias setting for a Bryston 3B ? | legarem | Solid State | 2 | 28th February 2008 08:02 PM |
| Having problem with a Bryston 3B | Unique | Solid State | 3 | 29th October 2007 11:14 PM |
| Bryston 3B-SST Reloaded | Sanken | Solid State | 5 | 21st August 2004 02:16 PM |
| Hafler DH200 vs. Bryston 3B | wrl | Solid State | 6 | 30th July 2003 07:23 AM |
| Page generated in 0.12118 seconds (86.83% PHP - 13.17% MySQL) with 11 queries |
