Voltage regulator issue - diyAudio
Old 12th January 2012, 11:17 PM   #1
Default Voltage regulator issue
I'm trying to build one of Rod Elliott's P05 preamp power supplies and have hit a bit of a snag. Using 7815 (+15v) and 7915 (-15v) gives me +14.5v and -17.4v. The first is within tolerance but the second isn't. I've swapped out 7915s and get the same thing. Set up a third 7915 with the test circuit shown in its spec sheet and, again, get the same.
1. Why does my 7915 give ~17.4V instead of 15V?
2. Does it matter for an opamp based pre-amp? Elliott's P88.
Old 12th January 2012, 11:39 PM   #2
Are you measuring the outputs with any load? Try a 1K resistor from the -v output to ground and see if it's in spec then
Old 12th January 2012, 11:40 PM   #3
Do have any load on -15 volt regulator?
Connect an led (with correct polarity) in series with 2k7 resistor and connect between +15v and -15V.
Then measure the -15v supply voltage.
Art
Old 12th January 2012, 11:42 PM   #4
Also watch the pinout. 78xx's are, looking at the front of the chip and reading left to right - Input, Ground, Output. The 79xx series are - Ground, Input, Output.
Old 13th January 2012, 12:06 AM   #5
Awesome. Hooked up 1k resistor and measured 14.99 across the leads. Thanks guys.
Voltage output issue with B1 Chris Adams Pass Labs 13 3rd October 2010 09:27 PM
LM3875 Amplifier Voltage Issue kblsnbts Chip Amps 8 6th March 2008 04:04 PM
new x.5-series voltage issue nightscalper Pass Labs 4 8th June 2006 07:46 PM
help! power supply voltage issue jlg4104 Tubes / Valves 15 2nd December 2002 07:35 PM
Copyright 1999-2017 diyAudio
