another amp schematic
Old 19th September 2003, 08:48 AM   #11
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
It surely needs a predriver/driver configuration
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 19th September 2003, 08:56 AM   #12
Jan Dupont's Avatar
Old 19th September 2003, 11:17 AM   #13
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Huh? It HAS a driver-predriver config doesn't it?
Jan Didden
Old 19th September 2003, 11:24 AM   #14
Jan Dupont's Avatar
Default Janneman
Yep!
Then it just need a driver-driver
Old 20th September 2003, 12:56 AM   #15
kevin gilmore is offline kevin gilmore  United States
quote
Didn't Bose use this design in their first (high) power amp?
Something damm close for sure. In 1975 i was in college
working part time for midwest hifi. We sold the bose
monstrocity. It sounded absolutely horrible. One weekend
i borrowed one, took it to the lab and tested it. High
frequencys were already down by about 4db at 10khz.
Way down at 20khz. Low frequencys were miserable
too. Distortion at rated spec was over 1%. What a piece
of marketing diatribe. Typical bose then. Typical bose now.
To be fair back then the crown dc300 and the phase linear
400 and 700 were all quasi-comp designs. And all of
these amps sounded much much better than the bose.
At less money too. (not a lot less money, but can't remember)
The fully complementary dynaco 400 and sae amps were
better still.
Old 20th September 2003, 07:48 AM   #16
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
the output transistors used had a 7amp IC rating, Pd of 150watts and Vceo 0f 250, so it can easily be replaced with mj21193/94 in a full complimentary circuit...the drivers can be mjw1302A/mjw3281A, the ic can be any of the latest variety of singles or duals.....the output stage itself has gain of 18x....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 22nd September 2003, 06:15 AM   #17
mozikluv is offline mozikluv  Philippines
Send a message via Yahoo to mozikluv
Default monster parallel amp
just for laughs guys ok? if you lack heaters in your home, this thing will do. he, he, he
"none but the brave deserves the fair" shakespeare
Old 23rd September 2003, 08:47 AM   #18
TonyTecson's Avatar
input is complimentary common-base with a gain of about 6, the second stage vas, is common emitter...the input buffer ic can be left out of the feedback loop.if it has a gain of 1...
Old 23rd December 2003, 10:00 PM   #19
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Cool Re: another amp schematic
Originally posted by C3PO
hi guys, anyone have an idea for these amp? does anyone here tried to build it?
Hi C3PO,
It looks a little bit like a Bose 1801 but is is not. The Bose had a differential stage after the opamp.
Old 23rd December 2003, 11:14 PM   #20
millwood is offline millwood  United States
Account Disabled
Originally posted by kevin gilmore
quote
the amp posted here has a bootstraped opamp as input. You can easily find better parts to build one like it. but why?
I have played with quite a few bootstraped opamp-based amps. They usually don't sound good.
One way to go may be using a high-voltage opamp, or even a power opamp (like lM3875) and use it to drive an output stage without the bootstrap. However, the only thing you gain there is higher current capabilities.
another amp schematicHide this!Advertise here!
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 02:49 PM
DBX 500 schematic d3imlay Solid State 0 2nd August 2008 06:12 PM
F3 schematic kenev Pass Labs 2 24th January 2008 04:24 PM
Need Six-pac amp schematic Sarge Tubes / Valves 1 31st July 2004 09:30 PM
