Plinius III 80 watt p/c class AB Amplifier
Old 17th December 2012, 10:21 AM   #61
Butcher is offline Butcher  New Zealand
Butcher's Avatar
mach1 no copy of the preamp just yet....
Old 11th January 2013, 11:11 AM   #62
Butcher's Avatar
Tonight I found the bag containing bits n' pieces off of the Plinius amplifier. I can confirm that inside the amp where two voltage regulators that fed the preamp. They are LM7924 and LM7824 so that's +24 volts and -24 volts respectively.
Tony.
Old 11th January 2013, 11:27 AM   #63
mach1 is offline mach1  Australia
Banned
Thanks Tony, I was sure the previous owner mentioned 24v.
Old 11th January 2013, 11:14 PM   #64
Butcher's Avatar
Yes that is right! Just posted the info so it was 100% factual! Of course sometimes manufacturers change specs during production (usually to cut costs down no less!)
Thanks mach1, Tony.
Old 25th January 2013, 10:20 AM   #65
philb123 is offline philb123  New Zealand
Just recieved a plinius 2b pre that has been rather badly 'fixed', mainly re-soldering some dodgy PCB tracks. Anyway.... in the process things would appear to have gone badly wrong. Anybody have a schemtic for this otherwise very tidy preamp so I can bring her back from the dead? Ta in advance.
Old 31st January 2013, 07:05 AM   #66
ooops, anyone with scematic for Plinius IIb pre will need this brasses@xtra.co.nz to send it to. Ta much
Old 26th March 2013, 11:58 AM   #67
Butcher's Avatar
RSK email sent. Cant recall if I sent schematic already!!
Tony
Old 26th March 2013, 12:52 PM   #68
RSK is offline RSK  Malaysia
Tony
Hi Tony,
Thank you for your kind mail. I got the schematic.
Raj
Old 30th June 2013, 10:43 AM   #69
Tiger Venter is offline Tiger Venter  New Zealand
Hi Tony, I am a Avionics engineer at Air NZ and fix amps for my mates I do love the old stuff as we can relate to it. The Plinius IIc and Plinius VIIb combination from 1984 landed with me. Please if jou have a schematic for the VIIb power amp. Email tierventer@xtra.co.nz
Old 5th July 2013, 10:54 PM   #70
Angry Plinius VIIc
Just answering my own question, I confirm that the Schematic for the III is good for the VIIIc. I traced it out only diff is that the power supply feed tru the emitter resistors to the rails. Will post the Schematic for others to use plus pictures. Keep a lookout! Also the drivers and output transistors are the Toshiba ones that is now obsolete 2SA1302 and 2SC3281 Be warned there is some fake ones out there!
Plinius III 80 watt p/c class AB AmplifierHide this!Advertise here!
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 4 14th February 2018 06:11 PM
80 Watt class-b amp 'L6' Ver 5.0 nyqxmfj Analog Line Level 2 30th November 2009 07:13 AM
2500 watt class AB hienrich Solid State 21 4th October 2007 11:03 AM
Class AB Amplifier USFishin Solid State 1 28th March 2004 04:25 PM
