Plinius III 80 watt p/c class AB Amplifier
Old 12th January 2012, 09:34 AM   #21
Butcher is offline Butcher  New Zealand
Butcher's Avatar
Check your email Steve.
Old 12th January 2012, 10:01 AM   #22
Butcher's Avatar
Yerk! I figured out how to upload the schematic!
Tony.
Old 12th January 2012, 07:54 PM   #23
srh is offline srh  New Zealand
Got it. Thanks very much. Do you have any info on the pre-amp and/or its power supply arrangement? I have a 2c without a power supply that I would like to get going.
Regards, Steve.
The older I get, the more simplicity appeals.
Old 12th January 2012, 08:04 PM   #24
Butcher's Avatar
Er, hi Steve! I remember (from few months back) that Plinius created external preamps after the Amp/Preamp line. I would like to see a photo (maby internal and external) as I have never layed eyes on one.
You could build one... All that is inside the Plinius III amp is a +- 15V rails. It is feed to the Plinius II preamp via a DIN plug. I will post the schematic for the Playmaster 60 - 60 Power Supply Section. I would decouple ALL the capacitors with 100nF and 10nF Film type capacitors.
Tony.
Old 12th January 2012, 08:08 PM   #25
Butcher's Avatar
Default Playmaster 60 - 60 Schematic (Power Supply)
Try this...
File Type: jpg Playmaster 60 - 60 Schematic (Power Supply).jpg (51.6 KB, 599 views)
Old 12th January 2012, 08:11 PM   #26
Butcher's Avatar
Also use four 1uF Tantalum, two per rail. directly across the 3 pin regulators. For decoupling. WATCH POLARITY!!!! I often blow tantalums up if I'm in a dopey mood! Especially with - rails!
Tony.
Old 12th January 2012, 08:21 PM   #27
Hi Tony, in the pre-amp there is a muting relay on the pre-amp output that is controlled by the poweramp. So the amp feeds + - 15v, 0v and a control signal for the muting relay. I will take some pix and send them to you tonight.
Steve.
Old 12th January 2012, 08:26 PM   #28
Butcher's Avatar
Thanks Steve. In my (brown) model, the mute relay is inside the Amplifier. Therefore NOT inside my model of Preamp!
Look forward to that srh!
Oh, and I am going to take some photos of my setup (modified) Plinius II and III (brown) and post them here for preservation of these old amps. I have gotten mine to sound like s*x. A 15 year project, I learnt SO much by doing this. Thanks guys...
Tony.
Old 12th January 2012, 08:45 PM   #29
Butcher's Avatar
Default Some photos I'd like to share.
There you go...
Tony.
File Type: jpg Power supply view (mains filter, bridge heatsinks).jpg (67.2 KB, 214 views)
File Type: jpg Star ground (mod), isolating preamp from power amp diodes (mod) - Birds Nest!.jpg (74.3 KB, 261 views)
Old 12th January 2012, 08:45 PM   #30
Butcher's Avatar
Needs a paint job one day!
Tony.
Plinius III 80 watt p/c class AB AmplifierHide this!Advertise here!
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 4 14th February 2018 06:11 PM
80 Watt class-b amp 'L6' Ver 5.0 nyqxmfj Analog Line Level 2 30th November 2009 07:13 AM
2500 watt class AB hienrich Solid State 21 4th October 2007 11:03 AM
Class AB Amplifier USFishin Solid State 1 28th March 2004 04:25 PM
