#101 | |
The buffer is 0.18" high and opc wants to couple heat in pcb to the heatsink Last edited by hochopeper; 13th January 2012 at 12:49 AM. |
#102 | |
Just DIY!
Do |
#103 |
Hi Guys,
I've attached a picture that shows the basis of the problem. The thermal resistance from the die to the outside of the case on a TO-263 pack is very high. It's of minimal use heatsinking to the top surface of the packages since the drop across the molding compound itself is so high. The tab and copper plane it's soldered to, on the other hand, has very low thermal resistance. Ideally, we should aim for a gap filling pad that actually has the TO-263 packages cut out of it, and then apply a small amount of thermal paste to the top of the packages and let the gap filling pad conduct heat from the top copper layer up to the heatsink. To be honest, it's not too big of a deal unless you plan on running these full out for long periods of time. I'm running my pair without any heatsink and they're just fine (if not a little toasty at about 58C) even during moderate use. The reason for the 0.2" height is that the buffer packages themselves are 0.180" high and the 0.2" height allows the gap filling pad to conform well around the edges and down onto the PCB itself. Cheers, Owen |
#104 |
is choosing a less facetious title...
Doh, of course. hey Owen, love the pimped out half brick recommendation. i use their BMR-C1 on individual to252, great stuff
i like the ribbed HC6158, but perhaps the rods have better thermal performance i'll have to check. GB anyone? i'm also thinking of contacting Richard at sumR Magnetics about a custom potted transformer to suit, as i know he has a few cans he can use to suit and will have one that will fit. we would need someone in Canada or the US to take delivery of the initial bulk order and send them out. i'm going to start a thread in the GB area in a moment for all the potential group buys we can do for this build. the buffers and lme49990 are an obvious addition and i mean the lme49610 as i cant see a downside for using these, even if you dont need the extra swing right now. pretty sure we could buy direct given the numbers we could possibly get. with 40 boards even if only 30 of us threw in thats 480 buffers and 180 lme49990 i would buy some extras of both at the price we would get. then we have heatsinks, transformers and the main 1210 size ceramics. also LT317/337 or LT1085/1033 and the power supply caps so who would we contact about getting a gap filler custom Die? and would it become a realistic solution with a number of us to get the cost down? you may be ok running in open air in Canadian winter, but boxed up in a 40c summers day in Australia doesnt sound like fun Last edited by qusp; 13th January 2012 at 01:31 AM. |
#105 |
What about custom machined heatsinks that have pockets machined out for the buffers?
![]() Edit: Like this: Last edited by HYPERTUNE; 13th January 2012 at 02:34 AM. |
#106 | |
![]() I would actually get in on a GB for the heatsinks and the LME49610 parts. Possibly transformers as well. I like the initiative! Keep me posted. Cheers, Owen |
#107 | |
On a second thought, the design is great as is
#108 |
Concept model attached above.
Give me some dimensions and I'll get on it. ![]() What do you think about having the heatsink threaded and screwed on from below the board? Edit: Rev1.1
#109 | |
What you have modeled would honestly be the ideal heatsink for this. Good contact with both the top of the buffer case and the PCB would allow the heatsink to provide the highest possible benefit.
The idle power is actually extremely low considering the performance (~4W for the output stage), and even at full tilt the dissipation isn't that bad. I personally would sleep better at night knowing that the buffers were as cool as possible though. Quote:
I can send you the dimensions for the board, screw locations, and buffer height/location. Would you be willing to take on making 30-50 of these? I would certainly be in for 6 of them. Cheers, Owen |
#110 | |
perhaps a slab of keratherm isolator between pcb and heatsink and just avoid the very front where the lme49990 are? the only problem i see with the bottom is it will increase the height of the completed unit I do LOVE the copper heatsink look Last edited by qusp; 13th January 2012 at 03:27 AM. |
| "The Wire" Ultra-High Performance Headphone Amplifier - PCB's | opc | Headphone Systems | 1835 | Yesterday 05:59 AM |
| Can I use MANY MANY low power devices for 1 HIGH power amp? | SkinnyBoy | Solid State | 34 | 14th May 2013 10:46 AM |
| Crowhurst High Power vs Low Power Amplifiers | avincenty | Tubes / Valves | 2 | 6th September 2011 01:34 AM |
| Super high current power inductor,low resistance.Digital amplifier special inductance | miden | Vendor's Bazaar | 0 | 14th August 2010 09:06 AM |
| FM Acoustics FM 1000 Ultra-High Power Amplifier, the absolute State of the Art? | tiefbassuebertr | Solid State | 0 | 28th October 2009 05:40 PM |
