#81 |
#82 |
enjoy...
#83 |
CORR.pdf
CORRECTED.pdf diy CHE amp output C.pdf diy CHE amp DRIVER S.pdf diy CHE amp OUT S.pdf diyCHE amp DRIVER C.pdf HEAT SINK.pdf |
#84 |
HELLO, CHESHTAP SIR NEW AMP PDF THIS PDF OLD
#85 | |
Output Power (8 ohms): 2 x 400 watts RMS Output power (4 ohms): 2 x 700 watts RMS Output Power (2 ohms): 2 x 1000 watts RMS Output Power (8 ohms bridged): 1250 watts RMS Output power (4 ohms bridged): 1700 watts RMS Output Circuit Type: Class AB Input Impedance: 10 kOhm Frequency response: 15 Hz - 25 kHz THD: <0.03% IMD 60 Hz and 7 kHz, 4:1: <0.038 Rise Time / Speed: 40 V / usec Signal to noise ratio:> 102 dB Damping factor:> 400 Cooling: Active Temperature Controlled Protection circuits: DC output protection, long-term overheating control, delay, soft-power start feature, overload protection, Clip limiter 2 x XLR inputs + 2 x XLR Thru output 2 x Speaker (SPK) outputs 2 channel speaker terminals Parallel / Stereo / Bridge - Fashion Normal / Compress - Fashion (clip limiter) Ground / lift mode Sensitivity switch: 1.44 V / 1.0 V / 0.7 V Power supply: 230 Volt Size (WxHxD): 482 x 383 x 88.8 mm Weight (net): 16.5 kg Weight (gross): 18 kg |
#86 |
so what is the output power now that the amp is in class h?
#87 |
Hi sir,.. can u send me full layout with sprint layout?... pls..
thanks and regards
Better try it ... ![]() |
#88 |
there is no sprint version, only pdf shared by cheshtap.
#89 |
ok nazir,... never mind...
thanks and regards
#90 |
hi nazir,. whether the steper ir2117 on each rail + and - works fine and does not limp voltage intake? or indeed as it is, because I put that steper rail - do not work or do not hv increased.
also most of the multiple-voltage HV on h900tef not work properly (there is a delay it).
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Adding a 12V power trigger switch to Electrocompaniet Power Amp | maxzimum | Solid State | 0 | 11th April 2008 01:54 PM |
| WIll an X-PSU v1 power an SI T-amp &/or TC754 pre-amp? | gnostic19 | Class D | 7 | 3rd August 2007 01:26 AM |
| High Freq. AC Power for Filaments of 300B SE Power Amp? | snoopyma | Tubes / Valves | 6 | 3rd January 2004 06:21 PM |
