Cheshtap Power Amp
Cheshtap Power Amp
Old 2nd February 2012, 10:25 PM   #21
NMOS is offline NMOS  Germany
NMOS's Avatar
Originally Posted by Gitsa View Post
Hi,this amp is the same scheme.
Chinese AODA
The origin China Manufacturer is AODA
www.cn-aoda.com
look here
Enping Aoda Electronic Technology Co., Ltd
Old 2nd February 2012, 10:29 PM   #22
NMOS's Avatar
PRONOMIC = old heavy technology from the past
you get for this much EUR SMPS light weight Class H amps
from LEX
Switching Mode Class H amplifier
German Distributor is available for LEX ....
Old 2nd February 2012, 10:42 PM   #23
Gitsa is offline Gitsa  Moldova
A similar scheme for the amplifier, but without the class G
Old 3rd February 2012, 03:49 PM   #24
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default chestap amp components
Hi Nazirdigi
greetings
1 104 250 volts better X2 ac
2 222 500 VOLTS
3 101 500 VOLT
4 100 UF 40 VOLTS
5 47 n 250 volts
warm regards
andrew lebon
Old 3rd February 2012, 04:13 PM   #25
wattaniya is offline wattaniya
thanks andrewlebon for the reply.
Old 3rd February 2012, 06:00 PM   #26
black is offline black  Romania
Send a message via ICQ to black Send a message via AIM to black Send a message via MSN to black Send a message via Yahoo to black
M10 is very very good amplifier best sound
Old 3rd February 2012, 06:25 PM   #27
this is ma 600 1050w/4 ohms
Old 21st April 2012, 06:46 AM   #28
hi irvynjay and andrewlebon,
pls guide me.
1-when first power up two led's lights on in the driver board,
2-i set dc offset to omv with the 500ohm preset.
3-i set the bias preset to half turn ,
4-protection section working with 12v dc,
-active led is on, when the 12vc power given,
-protection led is on, after relay active the led is off,
-when power off the amp, the clip led is light on and slowly off,
5-i provide signal to the amp, but out signal not comming, what will be the problem?
Old 21st April 2012, 03:14 PM   #29
Hi Nazirdigi
greetings please check NC/NO relay connections on pcb if i am not sure pcb track has to be cut
warm regards
andrew lebon
Old 21st April 2012, 07:04 PM   #30
Originally Posted by andrewlebon View Post
Hi Nazirdigi
warm regards
andrew lebon
Hi andrewlebon,
Thanks for the reply andrewlebon,
i already cut the pin from relay.
Cheshtap Power AmpHide this!Advertise here!
Are these iron core RF Inductors suitable for power amp power supply? HiFiNutNut Parts 7 26th November 2013 02:56 AM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
WIll an X-PSU v1 power an SI T-amp &/or TC754 pre-amp? gnostic19 Class D 7 3rd August 2007 02:26 AM
High Freq. AC Power for Filaments of 300B SE Power Amp? snoopyma Tubes / Valves 6 3rd January 2004 07:21 PM
Copyright ©1999-2017 diyAudio
