Old 16th January 2012, 02:33 PM   #11
Originally Posted by mj777 View Post
hi nazirdigi, how is your chestap amp, did you made it?
regards,
Marjohn
not yet.
Old 27th January 2012, 05:26 PM   #12
chestap amp pcb is ready.
Old 31st January 2012, 07:03 PM   #13
now top silk screen is finished.
i m buisy these days, thats why this work is getting long.
Old 1st February 2012, 10:19 AM   #14
hard working on cheshtap amp.
Old 1st February 2012, 10:21 AM   #15
hi irvenjay and andrewlebon,
can u give me the cap voltages i pointed in the image.
thanks.
Old 2nd February 2012, 06:42 PM   #16
HI,cheshtap,
can u tell me what are the exact voltages of this capacitor?
Old 2nd February 2012, 08:24 PM   #17
Gitsa is offline Gitsa  Moldova
Hi,this amp is the same scheme.
Old 2nd February 2012, 08:36 PM   #18
what is the power of this amp?
Old 2nd February 2012, 08:54 PM   #19
Ausgangsleistung (8 Ohm): 2 x 400 Watt RMS
Ausgangsleistung (4 Ohm): 2 x 700 Watt RMS
Ausgangsleistung (2 Ohm): 2 x 1000 Watt RMS
Ausgangsleistung (8 Ohm gebrückt): 1250 Watt RMS
Ausgangsleistung (4 Ohm gebrückt): 1700 Watt RMS
Ausgangs Schaltungstype: Class AB
Eingangs Impedanz: 10 kOhm
Frequenzgang: 15 Hz - 25 kHz
THD: < 0,03%
IMD 60 Hz & 7 KHz, 4:1: < 0,038
Anstiegszeit / -geschwindigkeit: 40 V / µsec
Signalrauschabstand: > 102 dB
Dämpfungsfaktor: > 400
Kühlung: Aktiv, Temperaturgeregelt
Schutzschaltungen: DC-Ausgang Schutz, Langzeit Überhitzungskontrolle, Einschaltverzögerung, Soft-Power-Start, intelligenter Überlastungsschutz, Clip Limiter
2 x XLR Eingang + 2 x XLR Thru Ausgang
2 x Speaker (SPK) Ausgänge
2 Kanal Lautsprecher- Schraubklemmen
Parallel / Stereo / Bridge - Mode
Normal / Compress - Mode (Clip Limiter)
Ground / Lift- Mode
Sensitivity-Schalter: 1,44V / 1,0V / 0,7V
elektrischer Anschluss: 230 Volt
Größe (LxHxT): 482 x 383 x 88,8 mm
Gewicht (Netto): 16,5 kg
Gewicht (Brutto): 18 kg
Old 2nd February 2012, 09:06 PM   #20
thanks for the reply gitsa.
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Adding a 12V power trigger switch to Electrocompaniet Power Amp maxzimum Solid State 0 11th April 2008 01:54 PM
WIll an X-PSU v1 power an SI T-amp &amp;/or TC754 pre-amp? gnostic19 Class D 7 3rd August 2007 01:26 AM
High Freq. AC Power for Filaments of 300B SE Power Amp? snoopyma Tubes / Valves 6 3rd January 2004 06:21 PM
Copyright ©1999-2013 diyAudio
