Old 6th January 2012, 01:21 PM   #1
Default STK4044 IC compatibility
Hi there, I am repairing a Grundig Fine Arts amplifier that has blown one channel. The amp is rated at 100W/channel and uses two STK4044-X IC chips. Whilst looking for replacements, I have seen an STK4044-V IC that I can get for under half the price. Will it work okay as a replacement? Ideally I should replace it with the exact type but I only have limited money to spend on the amp, on account of my car blowing its radiator
I have found the datasheet for the series of chips (link is listed below) and it lists some data but I'm hoping there is someone who can look at the figures and better explain the difference between the two and how it may alter the performance of the amp etc. Thanks in advance for any help anyone may have to offer.
Link to datasheet: http://www.alldatasheet.com/datashee.../STK4044X.html
Old 6th January 2012, 01:56 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
V version seems to be oldest. Normally all versions are compatible forward, but no always backward. Some better performance is expected in newer versions, by example, better noise figure, more gain, etc. In this case, appears not be any trouble.
LW1DSE
Old 6th January 2012, 02:12 PM   #3
tiefbassuebertr's Avatar
check out this threads:
Connecting STK hibryds... (especially post #12)
STK4141 is not always STK4141
Thick Film Hybrid (not monolithic) Integrated Circuit Amplifier - Overview
compare follow datasheets with the schematic in your service manual:
http://www.datasheetcatalog.org/data.../STK4044II.pdf
http://www.datasheetcatalog.org/data...o/STK4044V.pdf
http://pdf1.alldatasheet.com/datashe...STK4044XI.html
more URLs:
http://www.datasheetcatalog.org/data.../1638798_1.pdf (overview STK)
http://semicon.sanyo.com/en/hybrid/audio.php
http://www.turuta.md/demobook/STK-STR-2011-sample.pdf
http://www.eca.de/download/books/audiosample.pdf (STK go to 6-10 until 6-12)
http://www.sound-thinking.org/index.php?showtopic=3021 (post from June 16, 2007 05:10 pm)
all STK4044 versions:
http://semicon.sanyo.com/en/search/s...bmit322=Search
Old 7th January 2012, 11:49 AM   #4
I will probably get an STK4044XI chip as the replacement, including post it works out at the same cost as the STK4044V but looks to be newer than the STk4044X that it will be replacing and also has a lower distortion figure. If there is a noticeable difference between the left and right channels then I'll just replace the other side too.
If anyone has any reason for me not to use the 4044XI chip then please do tell me.
Old 8th January 2012, 08:52 AM   #5
djk is offline djk
djk's Avatar
Looks good.
Candidates for the Darwin Award should not read this author.
TDA7293/4 Compatibility Hakimi Chip Amps 1 14th January 2011 05:42 PM
search pcb with IC tl494 or other Ic to build a smps caraudio Ground Zero Car Audio 0 13th December 2010 04:58 PM
Cartridge compatibility davecooper Analogue Source 4 19th August 2010 11:38 AM
Opamp compatibility morfic Solid State 3 15th May 2009 09:54 PM
5.1 Stk4044&tda7296 gev Chip Amps 4 12th September 2007 02:36 PM
Page generated in 0.07958 seconds (76.02% PHP - 23.98% MySQL) with 10 queries
