Need help trouble shooting my BK ST 140
Old 5th January 2012, 02:59 AM   #1
Stuartarm is offline Stuartarm  Canada
Default Need help trouble shooting my BK ST 140
I have a BK ST 140 witch has one channel that works normal and one channel that is very weak and thin unless I turn the balance all the way to that side and crank up the volume high but even then then the bass is nearly non existent...I have swapped speakers, cables, interconnects and source so I know for sure the amp is the issue...I am an electrician but I'm no electronics tech...If any one had this issue and has resolved it I would greatly appreciate some feedback...thanks
Old 5th January 2012, 12:38 PM   #2
djk is offline djk
djk's Avatar
Check the cap in the feedback loop to ground, and the input cap.
Candidates for the Darwin Award should not read this author.
Old 11th January 2012, 07:51 AM   #3
Thanks djk...where would that be located?..I know the circuit board for the st 140 seems fairly simple looking...perhaps I should change all the caps??
Old 11th January 2012, 10:54 AM   #4
djk is offline djk
djk's Avatar
If you can provide a photo, I could mark it for you.
Otherwise, change all the small electrolytics (if over about 7 years old this is worthwhile anyway).
Old 21st February 2013, 08:42 AM   #5
thank djk...got me a crazy guy upstairs to replace the caps and yes there was improvement
Need help trouble shooting my BK ST 140Hide this!Advertise here!
B&k St-140 trouble shooting question nchakos Solid State 26 19th April 2013 03:11 PM
bk st-140 burned resistors shahsmerdis Solid State 2 1st December 2011 07:09 PM
BK st 140 evanc Swap Meet 0 10th April 2011 03:19 PM
Help trouble shooting Christof Tubes / Valves 11 1st September 2004 03:27 AM
need some trouble shooting help Jean Solid State 41 7th October 2002 05:53 AM
