high vac at speaker terminals rotel rb1070
Dear Hi Fi Gurus,
I am having some issues with my Rotel RB 1070 power amp. I have measured the vac on the speaker terminals at idle nothing connected and it is giving me 92 volts on the right side and 38 volts on the left side.
there is no dc voltage at all on the terminals. I had to replace a 10ohm resistor in series with a 0.1uf cap going to ground at the terminals as it got toasted. the new resistors get hot but so far have not burnt out.
As a newbie to how electrical circuits work I would like for some comments or suggestions on how to fix it.I can send it off to the repair man but I think that would be passing up an opportunity to learn something new.
I would welcome any suggestions on this.
thank you very much in advance.
regards
