Location: Where the world's best tea come from:Kericho Kenya
I've read in several posts about 'thinking of electrones as your car' so you should provide rounded corners or 45 degree bends. What's the need when component leads meet with the copper tracks at 90 degrees??
if there are no sparks,it probably doesn't work! |
#2 |
its a myth - audio frequency currents basically don't care about anything but the least resistance path
in PCB "design for manufacturability" some trace features are avoided because of etching limits, or rare failure mechanisms, some hypothetical, or out dated by improved materials, processing at RF frequencies, modern digital, the rules change because the high frequency components are sensitive to the waveguide/transmission line properties of the trace/plane geometry - then you don't want the impedance discontinuity of sharp 90 degree bends Last edited by jcx; 2nd January 2012 at 06:28 PM. |
#3 |
Electrons are yellow and more is better!
So in your case I think we can conclude this:
Short track as possible Cut corners or rounded corners = Looks good! It looks very unprofessional to have 90 deg angles on a pcb.
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
Keep tracks as short and as fat as possible.
45 degrees is good. Use a powerplane if possible.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#5 |
You need to think about what signals your tracks are carrying. If power, then wider tracks will give less voltage drop. If signal, then narrower tracks will give less capacitive coupling. In audio you may find that minimising loop area is more important than other things, so 'go' and 'return' paths should be near each other. Don't blindly follow rules (especially silly rules found on the internet); try understanding instead.
#6 | |
At audio frequencies the inductance and capacitance is to small to have the same effect as it does at R.F and the lower impedance of a 90 degree corner (due to the wider track width) will only make a tiny difference to the overall series impeadence |
#7 |
Its evident different diyers have different reasons. Even if rounded corners are used in RF signals pcbs,it seems to work for the famous musical Aksa55.
#8 |
Have you actually read post 6? Even where rounded corners are correctly used (RF) it has nothing to do with electrons' cornering speed.
#9 |
Sometimes a square peg fits a round hole just fine
yes i wondered about this too and acko explained it for me as above re impedance consistency/control. i would also think that perhaps even at some modern dac clock and DSP speeds that RF technique would not do any harm? certainly other RF technique is put to good use in dac layout.
#10 |
electrons do have mass, don't move too quick in room temp metals, strictly speaking it would be photons in their guise of EM fields that travel ~ 1/2 c in most transmission lines
for audio corners really don't matter except for how the size/orientation of loop areas change for mutual inducatance linkage |
| Rounding internal angles | ziocalepino | Full Range | 5 | 25th March 2011 03:13 PM |
| WTB: Harmonic Tech Cyber-Link Copper or Digital Copper cable | reaction | Swap Meet | 1 | 2nd July 2010 10:50 AM |
| Copper heatsink tweak - Thermaltake Copper Heatsinks | Ruach | Digital Source | 16 | 23rd September 2006 10:59 PM |
| angles for segmented ESL? | Few | Planars & Exotics | 21 | 25th February 2005 03:30 PM |
| DIY own copper tracks on blank boards | chris ma | Everything Else | 10 | 1st April 2004 08:33 PM |
| Page generated in 0.10459 seconds (78.63% PHP - 21.37% MySQL) with 10 queries |
