well it seems after ~5yrs my onkyo 805 has decided to relieve me of it's sub duties. i have double checked that my sub and fronts lp and hp settings are correct and the sub setting is 'on'. i've tried several cables and and cofirmed it with 3 different subs. any suggestions to look for? is there any way to measure the output at the rca with a multimeter?
help |
#2 |
The sub output comes off the speaker terminals via a 10K/680R network which mixes to mono and attenuates to line level. Check resistors R581, 582, 583 which are on the speaker output PCB. If the main speakers work and these resistors are intact, it should work providing there are no open circuits. Have a look at the connectors JL503A & B to see if the solder is cracked or wires are not broken.
Have a look at the R-805X schematic. |
#3 |
thanks Rabbitz, i will check those as soon as i have a chance.
looking at that diagrahm makes me curious how the AVR is able to adjust the HP/LP if it just seperates the sub feed with resistors? am i missing something? david |
#4 |
I've shown a little R-805X stereo mini receiver.
If it's a AVR, then it's a different model. |
| Onkyo amplifier A-RV401 - output signal to speakers cuts intermittently | gerolo | Chip Amps | 4 | 12th October 2010 08:03 PM |
| onkyo dx7711 tube output | costa23 | Digital Source | 0 | 2nd February 2010 04:04 AM |
| onkyo tx-nr901 center channel output not working | mayur32 | Solid State | 3 | 1st June 2008 06:34 PM |
| Onkyo Power Output Stage, capacitor between bases of EF pair? | capslock | Solid State | 5 | 13th April 2007 03:40 PM |
| about the 805 SE | tool0.0book | Chip Amps | 5 | 11th April 2006 02:56 AM |
| Page generated in 0.06900 seconds (75.55% PHP - 24.45% MySQL) with 11 queries |
