My amp is clipping with new speakers
Old 1st January 2012, 08:49 PM   #11
5th element is offline 5th element  United Kingdom
5th element's Avatar
That is odd indeed, what frequency are we talking about? The SR71s should be easy to drive and should not trigger the amplifiers protection circuitry (unless poorly designed) at only 15vp-p.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 1st January 2012, 09:07 PM   #12
benproiii is offline benproiii  United States
I build the amp myself and it does not have any speaker protection just DC offset protection.
Old 1st January 2012, 09:31 PM   #13
tvrgeek is offline tvrgeek  United States
Ah-ha, now you have the details. Yea, half rail seems a bit shy for the amp. Seems you have narrowed down the culprit. The SR71 does not look like a difficult load. If you amp poops out into a resistive load, I would look to see what might be incorrect before I started modifying it. Are the rails collapsing?
Old 1st January 2012, 09:32 PM   #14
kevinkr's Avatar
Something is definitely amiss in the power amplifier, sounds like the driver stages are running out of current (if this amp has bipolar output devices) before you even begin to approach the rails unless they are sagging drastically under load which is probably the next thing to check.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 1st January 2012, 09:32 PM   #15
I think there is something wrong with the amp.
I connected the amp to a function generator and sent a 1KHz sine wave into it.
I connected an AC meter and oscilloscope to the amp output with NO LOAD and the max volts the amp will make before clipping is 14.9VAC on the meter with 700mv into it.
Old 1st January 2012, 09:45 PM   #16
By the way, how do you like the SR71's?
Old 1st January 2012, 09:47 PM   #17
I love the SR71's I'm new to the (Audiophile) world and I have never heard speakers that sounded this clear and refined.
Old 1st January 2012, 10:01 PM   #18
Here is the circuit I am using for my amp including the HFE grades. It's zobel is on the binding posts thats why its not in the circuit. Do you see any major flaws in the circuit.
Old 1st January 2012, 10:24 PM   #19
amptech is offline amptech  Scotland
Send a message via MSN to amptech
Benproiii, try this remove c7/c8 r7/r6/ and c19..replace c10/c11 with 100uf and c4/9 with 100nf. c20 up it to 47uf.
add a 10uf bp at the input of the amp...
Old 1st January 2012, 10:33 PM   #20
godfrey is offline godfrey  South Africa
@benproii:
Nothing obvious, although it is different to the HRII schematic I found on Greg's website (so FWIW, my earlier comments about zeners don't apply here).
I suppose the first thing to check is all the supply rail voltages, as shown below.
@amptech:
Why? Changing C20 may improve the bass and adding an input cap will reduce the chance of DC offset, but none of those changes will fix the actual problem.
My amp is clipping with new speakersHide this!Advertise here!
Early clipping with JX Amp JBL4435 Pass Labs 32 8th December 2011 07:05 AM
Recovery from clipping, soft clipping hahfran Solid State 49 23rd February 2010 01:03 AM
Super T Amp Clipping ! any suggestions ? audioaction Class D 4 5th January 2010 03:11 AM
Amp clipping detector Bazukaz Solid State 8 27th February 2009 02:47 PM
Clipping and amp power supply digitaldisaster Chip Amps 3 3rd September 2007 03:53 AM
Copyright ©1999-2017 diyAudio
