Can such a simple trick nail MOSFET gate capacitance to a constant?
I have never seen an ESBT self-biased in this way before, is it new? Can we now use MOSFET without squirming cap at stOOpid low VDS? ------ And a trio provides base current... Last edited by kenpeter; 31st December 2011 at 02:04 AM. |
#2 |
Ken,
It's clever, but precisely what problem does it solve? Hugh |
#3 |
Source switched MOSFET? (optimally different types of course).
#4 |
Unpredictable Miller capacitance at Low VDS.
Imagine the gate capacitance as-if an air bubble were squishing back and forth from source to drain under a piece of Scotch Tape. Situation I wish to avoid... Nothing against the Scotch. Last edited by kenpeter; 31st December 2011 at 02:50 AM. |
#5 |
Working an FET with Drain below turn-on voltage puts you into a very different mode of operation, with soft "plate resistance" and lower and more-variable Gm.
In a sense, instead of squishy C skewing your highs you have squishy resistance parameters skewing everything. Your Trio looks to me like a 3-stage amplifier which is liable to self-oscillate. Have you tried these on breadboard? |
#6 | |
Wouldn't it be easier just to use an ESBT as intended? You get almost constant voltage across the MOSFET. Judging from the pic below (swiped from a datasheet), it seems normal to run these things with very low Vds. BTW, Nelson Pass mentioned awhile ago that he'd been playing with ESBTs. I wonder if anything interesting will come of that? |
#7 | |
two could be squishy? Gm might be reduced or curved or both... Some curves are useful. If it turned out to be square law, that might be a very good thing. Other curves, maybe not so useful. But my magic eight ball don't tell me whats gonna happen. Time to consult the entrails on a breadboard, or whatever... Last edited by kenpeter; 2nd January 2012 at 06:17 PM. |
#8 |
Looks interesting,
http://www.st.com/internet/com/TECHN...ivCta_2008.pdf Look at the linearity in fig6
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| Origins of the Baxandall Super Pair? | jez | Solid State | 22 | 30th December 2011 06:40 PM |
| Pair of Fostex T500AmkII Super Tweeter | nightyj | Swap Meet | 4 | 31st October 2011 09:17 PM |
| Fs: pair of fostex t90a super tweeters | tiverson | Swap Meet | 5 | 23rd October 2011 02:47 PM |
| FS: a pair of Fostex t900a super tweeters | tiverson | Swap Meet | 2 | 28th February 2011 06:14 PM |
| Baxandall Super Pair | peufeu | Solid State | 85 | 2nd November 2009 08:14 AM |
| Page generated in 0.09832 seconds (80.70% PHP - 19.30% MySQL) with 11 queries |
