I want to see your amps!
Old 27th January 2002, 08:35 PM   #11
kiwi_abroad is offline kiwi_abroad  New Zealand
kiwi_abroad's Avatar
Hi All,
I think it would be a great enhancement for www.diyaudio.com to have a gallery page, similar to that on Nelson Pass's site, but for all comers. I for one love looking at others creations, amps, preamps and speakers (a picture is worth a thousand words etc ...)
How about it??
Cheers, Adrian
Old 27th January 2002, 08:43 PM   #12
PH104 is offline PH104  United States
PH104's Avatar
Great idea.
Old 27th January 2002, 08:50 PM   #13
sonnya is offline sonnya  Denmark
sonnya's Avatar
Well... I thought it was in Hifi Fidelity i have seen them!! But i was a bit afraid of being wrong...Congratulations!!
Sonny
Old 28th January 2002, 10:15 AM   #14
ih is offline ih
Send a message via ICQ to ih
Man, Flemming J P - they look like some serious amps. What are they capable of?
Maybe something like the PCDB would work well?
Old 28th January 2002, 10:29 AM   #15
Flemming J P is offline Flemming J P
Send a message via MSN to Flemming J P
They were build (not by me though) for low impedance speakers.
150 watt in 8 ohm
near 300 watt in 4 ohm
near 600 watt in 2 ohm
approx. 1000 watt in 1 ohm (the resistors went up in smoke too fast to get a proper reading)
They have a switch so they can be baised for 1 or 100 watt class A, I haven't been able to tell the difference, except for the heat.
I can't rember which transistors are used in the output stage except that they are not mofsets.
Old 28th January 2002, 12:57 PM   #16
hifi is offline hifi  Sweden
Nice....Whats the rating on the RIFA:s?...and the transformer?... My aleph 2 clone ways about 25-30Kg a pc (but its not fully assemblaged jet....
30x30x4cm heatsinks 2 pc per block =)) 10kg aproxx
5mm T6 Alu all around it should be used to make boats =) but then i got hold of it =) 8kg aproxx
900VA toroid audio grade 10Kg aproxx
2pc 47000F Rifa Peh169 10yers in hard use life expectancy.....
2pc 1.1mH coil about 0,7Kg a piece same as for caps...
+Some more fun stuff like remote turn on and some voltage checks (to be fed to display on preamp..whenever i get around to it..)
hmmmm ....=) i will post some pics of it when it is possible..
/micke
Old 28th January 2002, 01:38 PM   #17
The RIFAs are 47000uf long life, haven't read the rest. The main transformer for the output stage is a 1000VA, the smaller one on top is a approx. 500VA for the other stages.
Normaly weight is a good thing, but when moving them down from 4. floor, then it kind of sucks
Sounds like you will also end up with some solid state
Old 28th January 2002, 01:57 PM   #18
damn then its almost 0,3F in each of those thins....damn....;-)
Old 28th January 2002, 02:12 PM   #19
sonnya's Avatar
RIFA ... Ohhh One of the finest CAPS you can get... They are not cheap!!! I have 2 of them in my own amp... Price before VAT and Transport ... 600 - 700DKR each.
.3 Farad should keep the amp alive for some seconds!!!!! after the power have been removed!!
Sonny
Old 28th January 2002, 03:07 PM   #20
I think ELFA is cheapest...i bougt some for 275SEK a piece + VAT thats a 47mF/63V cap....
esr 5mR =)) i got 5 of them brand new in about one meter from where i sit now....=) when im finished this post i will pick up one of them to have a look ...
/micke
I want to see your amps!Hide this!Advertise here!
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 20 12th May 2015 12:23 PM
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 10:27 PM
Why do some Bogan amps sound so good as guitar amps? amperex Instruments and Amps 7 22nd June 2006 11:46 AM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 01:33 AM
Copyright ©1999-2017 diyAudio
