Old 26th December 2011, 09:34 PM   #1
Default Help with waveform on rails - looks unregulated
Hello,
While troubleshooting a dead channel on a QED amp I put the scope on the rails and I get what looks like partially rectified waveform, plus 3 phases?
Is my scope broken?
I mean normally the scope works fine. Why 3 phases? Positive end of rectifier bridge shows large sine 1/2 waves. Negative shows smaller ones.
Thnanks.
Old 26th December 2011, 10:56 PM   #2
JoelS is offline JoelS  United States
that kind of look on the scope has to do with the way the triggering is working. there can only be one voltage at any instant of time, but if you believe what the scope is telling you here then there is 3 different voltages at each instant. play with the trigger level, or use more time per division, this should clean up.
is that supposed to be the regulated voltage? maybe the main filter caps after the bridge are not working, or dead regulator
-Joel
Old 27th December 2011, 01:22 AM   #3
It's a triggering problem. Try setting the trigger source to LINE.
Old 27th December 2011, 01:28 AM   #4
Yes the trigger is not working.
In the first pic looks like you have one shorted diode in the power supply bridge.
Old 27th December 2011, 01:10 PM   #5
Thanks !
Unregulated Power Supply maxseeley Vendor's Bazaar 1 18th October 2011 06:41 PM
Benefits/Drawbacks of Dual rails vs Single Rails buzzforb Pass Labs 2 25th May 2011 01:06 PM
Understanding unregulated PSU Nikon1975 Tubes / Valves 4 1st March 2010 04:06 AM
Unregulated PSU MarcH Solid State 8 8th June 2008 09:35 AM
+8V unregulated? PhantomBox Parts 1 15th February 2008 10:08 PM
Page generated in 0.06043 seconds (81.98% PHP - 18.02% MySQL) with 11 queries
