I'm very new to solid state designs, and I'm attempting to design a high voltage amplifier to drive the grids of output tubes.
I whipped this up (see attachment) in LTSpice and it works, suspiciously well in fact, I'm getting readings of 0.009% distortion at 20Khz while swinging 100V P-P into the 10k load resistor, with the gain set to 100 (well, near enough) Now, I'm not 100% trustworthy of this result, seeing as it seems pretty good, and I basically happened upon this design by accident / fiddling. For example, I'm not sure if my current mirror is actually doing anything useful, as it's driving the low impedance input of the VAS transistor. Basically it would be really great if someone could look over this design for me and suggest improvements where possible Thanks for any help |
#2 |
What tube are you driving?
#3 |
#4 |
what is the advantage in this approach, over say, an all-tube design ? - is it simply that you have lower distortion given all the nfb ?
It would be interesting to hear this circuit, if the distortion is really low it would allow the harmonic signature of the output tube to come through.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#5 |
Don't forget that any circuit which relies on transistor balance (e.g. LTP, current mirror) will always simulate with lower distortion than in real life.
#6 | |
Does anyone have any comment on the circuit itself? Am I doing anything stupid? Are there faster / better transistors I could use? |
#7 | |
As a starter: a current mirror usually benefits greatly from emitter degeneration, e.g. to reduce noise and sensitivity to transistor mismatch. Samuel |
#8 | |
I added 100 ohm resistors to the current mirror and it increased the overall open loop gain somewhat and of course would have the positive effect you described of being less critical about transistor mismatch |
#9 |
forgive my ignorance but what are the parts that look like filter caps marked a V1 through V6 ? Are these d.c. batteries you are using in an active circuit ?
#10 |
Tubes are voltage amplifiers ( rather "charge change amplifiers) and BJTs are current amplifiers. The respective physics of amplification are entirely different.
It makes no sense to drive a voltage amp with a current amp you could easily replace the BJT high V with one or two tubes and stay so to speak in one family of amplification. |
| Which opamp was used for the Adcom 6AA opamp ? | gaetan8888 | Digital Source | 3 | 20th December 2010 07:17 AM |
| HV benchtop power supply, help on opamp setup | panos29 | Tubes / Valves | 17 | 20th April 2008 10:27 AM |
| WTB Krell KSA Mk2- working or non working | Jozua | Swap Meet | 0 | 20th March 2006 11:14 AM |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 02:15 PM |
| Regulate the psu of a power opamp with a similar power opamp? | Franz G | Chip Amps | 34 | 19th October 2004 10:49 AM |
| Page generated in 0.10952 seconds (78.57% PHP - 21.43% MySQL) with 11 queries |
