diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Would you calculate and re-draw the circuit overcurrent protection ? (http://www.diyaudio.com/forums/solid-state/203141-would-you-calculate-re-draw-circuit-overcurrent-protection.html)
umut1001 25th December 2011 06:44 PM
1 Attachment(s)
Would you calculate and re-draw the circuit overcurrent protection??
thanks...
wahab 25th December 2011 07:18 PM
Originally Posted by umut1001 (http://www.diyaudio.com/forums/solid-state/203141-would-you-calculate-re-draw-circuit-overcurrent-protection.html#post2834001)
thanks...
There s no protection in this amp.
This schematic is the application note of Hitachi for their
lateral fet devices , although this version has different resistors
values , the 47pF compensation is also at the wrong place as
it should be connected between base and collector of the facing
MJE340.
You can add a diode and a zener in serial from gate and drain
of the of the fets to provide some current limitation.
umut1001 25th December 2011 07:33 PM
Hello.It is for my friend.His English is not good enough.He meant "would you calculate and draw a circuit protection for this amp" Thanks in advance
djk 26th December 2011 04:02 AM
All that is needed for this 50W/8Ω amplifier is a 3A fuse on the speaker out, 10V gate zener diodes, and a 85C thermal switch on the heatsink.
Copyright 1999-2017 diyAudio
