Old 23rd December 2011, 01:54 PM   #1
lemon is offline lemon  Greece
Default Aaron Millenium 3, outputs tranzistors & quiescent current
Hi @all,
I have an Aaron Millenium 3, ver1.1 (20/06/2005) with problem on an output tranzistor - left channel - (unfortunately the signs of tranzistor has deleted from the factory).
I have find the following pcb schematic and according to this, the outputs tranzistor are pairs of MJ15003/15004. Is that true and happens to all Aaron versions?
If you have any other schematics about this final amplifier, I will appreciated!
If you can help me about how to set right the quiescent current, I will appreciated too (procedure and values).
Old 23rd December 2011, 04:24 PM   #2
My Aaron is fitted with MJ15003/4 outputs.
Aaron literature tells lies about the low impedance capability of their amplifiers.
regards Andrew T.
Old 23rd December 2011, 05:37 PM   #3
Do you know, what pcb revision has it? - there is a refference about this, under each pcb.
What you meaning, exactly with "Aaron literature tells lies about the low impedance capability of their amplifiers"?
Old 23rd December 2011, 07:42 PM   #4
They state the power output into 8r0, 4r0, 2r0 and 1r0 loads.
regards Andrew T.
Old 25th December 2011, 06:35 AM   #5
Aaron says:
Output power continuous sine wave per channel:
100W/8Ω 0.1% THD
160W/4Ω 0.1% THD
Output power pulsed per channel:
350W/2Ω 0.1% THD
410W/1Ω 0.1% THD
At the low impedance loads the "secret" is the term "pulsed"...they don't use the term "sine wave". Factory trick!
I have the equipment to measure all of this, but I haven't the appropriate "dummy load" for this power. Usually, I use "dummy load" until 60W/4-8 Ohm.
Yesterday, I found the problem to the right channel and fixed. I have some measures (thd+N, imd) between left & right channel (left has the new MJ15003/15004G, right has the factory tranzistor).
I will upload to my next message.
Cheers.
Old 4th January 2012, 09:40 AM   #6
Happy New Year to all!
I come back with my Aaron No3. Millennium.
At listening test, everything is OK, but if you place your ear to the right speaker there is a "zzzz" from midrange & tweeter.
This appears and with thd+N metering, that there is a difference 0.023% vs 0.073%, with the noise threshold at the R channel more higher. I believe that the cause must be some transistor.
THD+N(%) Left Channel
THD+N(%) Right Channel
Also, my pcb differs from above schema (first message). I have per pcb 18 tranzistors vs 17 tranzistor that appears at the schema. I have enclosed two photos from my pcb.
I would be happy if someone gave me an extra pcb schema like mine board.
Old 10th January 2012, 11:56 AM   #7
Originally Posted by AndrewT View Post
My Aaron is fitted with MJ15003/4 outputs...
Is your amp, Aaron 3 or Aaron No3. Millennium?
Old 10th January 2012, 12:05 PM   #8
Aaron No.3 Millennium
Here, you will find the right connection for the best speakers.
With output of
2 x 100 Watt at 8 Ohm
2 x 180 Watt at 4 Ohm
2 x 320 Watt at 2 Ohm
2 x 550 Watt at 1 Ohm
the No.3 Millennium is of course able to drive even impedance-critical speaker systems.
this is the lies. It's from
http://aaron.hifi.net/intl/no3.html
regards Andrew T.
Old 10th January 2012, 01:49 PM   #9
tiefbassuebertr's Avatar
most likely it is, that one of the transistors T1-4 has been noisy.
Check also the zeners Z1+Z2 so as the electrolytics C2+C3 (perhaps you add bypass caps, e. g. WIMA MKS, 1uF - 4,7uF).
What happens with the difference in noise, if you short the input to GND (short therefore C1 resp. R2) ?
About
http://new.audiogon.com/listings/433779
there are various pics.
Old 10th January 2012, 03:28 PM   #10
- I agree with you, AndrewT. There is a "trick" at 2 & 1 Ohm from Aaron (pulse measuring).
Please, it is very important to me. You said that yours Aaron output transistor are pairs MJ15003/15004. Have you Aaron 3 or Aaron No3 Millennium?
About
Aaron No.3 Millennium Stereo High End Amplifier | Solid | AudiogoN
- Thanks for the respond to me "tiefbassuebertr". The problem has resolved. There was a "cold" soldering at the ground of left channel at the rca input. Now everything is OK.
To all members: I am looking for the kind of output transistor of Aaron No3. Millennium and if there is a pcb diagram, it is welcome!
what is quiescent current on rockford amp Ground Zero Car Audio 2 15th August 2009 03:23 PM
LM3886 Quiescent current NITRO Chip Amps 4 20th April 2005 10:06 PM
measuring quiescent current of power amp question crippledchicken Solid State 2 19th November 2004 10:57 PM
LM3886 and it's quiescent current Toster Chip Amps 5 5th May 2003 10:23 PM
Quiescent Current JohnClark Solid State 13 16th November 2001 08:20 PM
Page generated in 0.13089 seconds (82.37% PHP - 17.63% MySQL) with 11 queries
