Need some help with Class A JLH power parameters
Old 23rd December 2011, 03:06 PM   #11
kenpeter is offline kenpeter  United States
Originally Posted by Nico Ras View Post
Kenpeter, give and example of your suggestion it may be interesting to try.
These four parts grafted onto your existing JLH...
Turn it into square law vs square law Class A, and a lot less heat.
Afterthoughts of this hurried drawing:
Q1 ought to be on or near output heatsink, so it can feel the heat.
BD139 has a mounting hole for such purposes , 2n2222 does not.
2n2222 probably wasn't the best choice I could have illustrated.
The Schottky diodes should never be bolted to the output sink, but
bent away in a slightly cooler location. This (and Q1 at full heat)
assures the shunting will shape a safe temperature coefficient.
Old 23rd December 2011, 06:27 PM   #12
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Originally Posted by AndrewT View Post
I don't know why you stated such.
The Krell KSA50 is a ClassA amplifier that achieves 50W of ClassA output into 8r0.
The maximum output from a single ended ClassA amplifier is equal to the output stage bias current. The JLH is not a ClassA SE output stage. It has some form of modulated bias.
The maximum output from a Push-Pull ClassA amplifier is equal to twice the output stage bias current. Some of the later Krells were not ClassA, they had some form of modulated bias.
If the KSA50 has a bias of 1.9A, then the maximum ClassA output current is <3.8Apk. The maximum ClassA power output is <3.8^2 * 8r0 / 2 < 57W, but not as low as 28.8W
You are right 57 watt peak, but KSA remains just an over biased class AB, you can bias a KSA50 as low as a few mA.
Kindest regards
Nico
Old 23rd December 2011, 06:28 PM   #13
Nico Ras's Avatar
Thanks Kenpeter, I will try your idea tomorrow and report on the practical finding -
Kindest regards
Nico
Old 23rd December 2011, 07:55 PM   #14
AndrewT is online now AndrewT  Scotland
No the peak power output or instantaneous maximum is ~116W into 8r0, from 3.8Apk and 30.4Vpk
It is not a Krell KSA50, if you choose to ignore the manufacturer's set up information and miss-set the bias to less than 1.9A
regards Andrew T.
Old 24th December 2011, 12:41 AM   #15
You might throw a switch across one or both of those Schottkys.
Any less than 0.65V total drop across here will shut off Q1, and
return the circuit back to normal (extremely warm) JLH operation.
A DPST switch might also provide convenient mounting location
for Schottkys? Since there are tempco benefits for these to be
away from the heat that Q1 is sensing.
Even if you got tempco completely wrong, and Schottkys run away:
Our worst case is merely a return to normal JLH, just as-if shorted
on purpose by the switch. Only of concern if cheating with smaller
heatsink than JLH would normally require.
I don't forsee any such problem. As these diodes are TO-220, and
not dropping enough voltage to make significant heat of their own..
Wire loss to such a switch only makes the current sensing more
stable (slightly resistive) , so a remote diode mounting is fine.
Make sure your Schottkys are not rated in excess of the maximum
current you need them to carry. Else you may not be riding on the
best part of the square law curve.
Old 24th December 2011, 10:36 AM   #16
Nico Ras's Avatar
It is not a Krell KSA50, if you choose to ignore the manufacturer's set up information and miss-set the bias to less than 1.9A.....
If the KSA50 has a bias of 1.9A, then the maximum ClassA output current is <3.8Apk. The maximum ClassA power output is <3.8^2 * 8r0 / 2 < 57W, but not as low as 28.8W.....
Whatever...
BTW. I never said JLH is SE, I said the only real class A is SE. Kindly explain the modulated bias you propose for JLH?
You cannot run this JLH in class B, but you can run a KSA50 in class B so KSA remains an over biased class B
Kindest regards
Nico
Old 24th December 2011, 10:41 AM   #17
Nico Ras's Avatar
Hi Kenpeter, tried it and your idea works. It runs cold, only thing is the distortion is very much audible now. I tried different values of R which changes both the power dissipation and distortion. The higher the dissipation the less the distortion. When I say audible it is quite obvious, probably 5% or more (subjectively).
Kindest regards
Nico
Old 24th December 2011, 11:07 AM   #18
I don't understand the active bias part of the JLH.
What I can confirm is that the output bias varies with through put signal level.
But I don't know how to prove that.
As to your other point.
Your SE to PP comparison is in effect claiming that only SE can be ClassA and that PP must always be ClassB or ClassAB.
In my opinion that claim is completely wrong.
I state and firmly believe that both SE and PP can be ClassA.
regards Andrew T.
Old 24th December 2011, 11:22 AM   #19
toprepairman is offline toprepairman  United Kingdom
Hi Nico. Andrew is correct, regardless as to whether it is single ended or pushpull, if the bias is such that the output devices are always conducting (and not any strange sliding bias idea) then it is class A.
Old 24th December 2011, 11:25 AM   #20
THe JLH is biassed for half peak output current, and being pushpulll this is a proper class A design.
A single ended design has other considerations depending on whether it is choke/transformer coupled/loaded or resistive or constant current fed.
Need some help with Class A JLH power parametersHide this!Advertise here!
JLH Headphone Class A kacernator Solid State 1 10th June 2011 08:48 AM
JLH Class A PCBs? tommytube Solid State 8 20th October 2005 08:15 PM
JLH class a with a SMPS?? Possible? JZatopa Solid State 2 27th March 2005 04:47 PM
JLH Class A power supplies David H Solid State 1 17th August 2001 04:18 PM
JLH Class-A Amplifier Geoff Solid State 5 25th May 2001 11:55 PM
Copyright ©1999-2017 diyAudio
