The Amp I use for my bass units
Old 22nd December 2011, 06:38 AM   #1
Mambo is offline Mambo  Italy
Default The Amp I use for my bass units
Hi All,
I'd like to present You the amp I'm currently using to drive my bass units built with the CIARE HW380 woofer
It almost uses the Douglas Self "Load Invariant" base schema with 6 output pairs of MJL1302A/3281A for each channel, driven by MJE15034/15035.
I put it under a scope and found the following numbers at the first signs of clipping:
160W/8Ohm stereo
510W/8Ohm bridge
800W/4Ohm bridge
The overall protection is built on rail fuses and the delayed relè which is also controlled by an output DC sensing circuit.
A 230V power relè almost immediately shorts a 50Ohm 50W resistor in series with the primary of the 800VA transformer
Old 22nd December 2011, 07:03 PM   #2
R.I.P.
Difficult to tell, but your star ground in the middle of your smoothing caps looks like it is also being used as your Main Audio Ground.
regards Andrew T.
Old 22nd December 2011, 08:32 PM   #3
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by Mambo View Post
Hi All,
160W/8Ohm stereo
510W/8Ohm bridge
800W/4Ohm bridge
you are getting 800watts output from an 800va transformer ...?
Old 22nd December 2011, 09:07 PM   #4
wg_ski is offline wg_ski  United States
Yep. It's positively scary how much one of those things will put out into a short circuit. You can run one about 3x for at least half an hour before anything nasty happens. They don't just 'quit' when you request more than the rating for a fraction of a cycle... unlike switchers which do.
Old 22nd December 2011, 09:23 PM   #5
valo is offline valo  Norway
valo's Avatar
nice work !
http://www.polarboing.com
Old 22nd December 2011, 11:14 PM   #6
gain wire is offline gain wire  Canada
gain wire's Avatar
that's a monster amplifier! And the construction is superb!
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 23rd December 2011, 06:40 AM   #7
@AndrewT: the Audio Ground is collected on a sort of second start-ground few centimeters away from the main start ground, You can see it between the supply capacitors and the transformers.
Yes, I'm getting 800W @4Ohm bridge and tested with a 100Hz sine wave with a duty cycle of 5s ON and 15 OFF for some minutes after some wrming up at 50W, so It has not been a very hard work for the transformer. Above all I set the limiter on the DCX2496 which is driving it exactly @800W/4Ohm, so I will never exceed the RMS power also when used outdoor; I know this way I'm not getting the maximum peak power but i don't have any method for getting a visible measure of it.
The amp has a total of 166000uF storage capacity (2x39000 + 4x22000) so I'm quite sure it will be able to put out 900W/4Ohm bridge for 50ms peaks
I'm alredy working on a clip indicator based on the Nakamichi PA7 schema, which will be assembled in "free air" and in the future i think i will add a limiter circuit based on the LM13700, like the one I'm working for my new Class G project
Old 23rd December 2011, 10:53 AM   #8
R.I.P.
do you realise what you have said?
short circuit = zero ohms.
The output power is defined by Po= Imax^2 * Rload.
If Rload is zero ohms then the delivered power Po is zero Watts.
regards Andrew T.
The Amp I use for my bass unitsHide this!Advertise here!
Bass units as stands davecooper Subwoofers 8 6th January 2011 12:08 PM
Pleated Fabric Surround Bass Drive Units calvert73 Subwoofers 10 31st January 2010 12:45 AM
Unknown mid/bass units Masuji Multi-Way 0 20th December 2005 12:17 AM
Epos es14 Bass drive units? niknik Multi-Way 1 24th October 2004 08:54 AM
Maplins close-out on Audax bass units Mark25 Multi-Way 15 28th June 2004 12:33 AM
