HAL SYMFET
HAL SYMFET
Old 20th January 2012, 02:39 PM   #21
OnAudio is offline OnAudio
OnAudio's Avatar
Hi Raj,
It will work with two pairs but the current will be limited to 14A. If you want to boost the rails you can but with modifications here and there. The posted schematic uses +/-40V with a rated output capability of 21A.
kind regards
H.
Old 20th January 2012, 07:02 PM   #22
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
What are you driving with 21 amps? Rated means continuous, which is rms, what should the transformer rating be 2KVA, per amp?
Kindest regards
Nico
Old 20th January 2012, 09:36 PM   #23
OnAudio's Avatar
400VA should be fine
Old 21st January 2012, 06:54 AM   #24
RSK is offline RSK  Malaysia
Originally Posted by OnAudio View Post
Hi Raj,
kind regards
H.
Alright Harrison,
I will remain at +/-40Vdc. Its only for normal home listening.
Thank you and regards.
HAL SYMFETHide this!Advertise here!
HAL PREAMPLIFIERS OnAudio Solid State 86 19th March 2012 06:47 AM
A certain HAL Amplifier OnAudio Solid State 0 23rd November 2011 03:41 PM
SymFet - The Small Amplifier lineup Solid State 10 23rd January 2011 11:53 PM
HAL-O Damping Instruments Tazzy Tubes / Valves 7 14th October 2004 02:24 AM
