Electrons are yellow and more is better!
Hi!
I'm planning to go ahead with my Alexander since I have got green light from Analog Devices. The thing I wonder about is which opamp I should use. http://www.analog.com/UploadedFiles/...17334AN211.pdf http://home.swipnet.se/~w-50719/hifi/qrv03 OP97 is the original. Offset less than 1 mV Small bias currents Current consumption less than 1 mA Any good alternatives?
/Per-Anders (my first name) or P-A as my friends call me |
#2 |
This looks like a great amp! Unique design approach. 2 questions though...
I believe the SSM2131 is discontinued... what will you be using instead? Are you doing your own PCB's? |
#3 |
I'll guess you don't have seen the present amp? Check the qrv-03 which a korean guy has built.
The opamps in mind are "any" modern. Pcbs, yes, but this design is protected by a patent so I have had a low profile until I have got green light from AD.
#4 |
Peranders
I done several integrators for commercial application zero out offset. The opamp used is a OP07A. It not fast and has very low offset.
Jim W. |
#5 |
One of the main parameters is current consumption because of the current feedback thing. 0.1-0.5 mA would have been nice.
OP07 is OK if you have a "normal" DC-servo application, but this is rather unusual.
#6 |
Hi Peranders
The danish HI-FI magazine Highfidelity once had an project on this amp, the people who builded it all complained about lack of deep bass but were much impressed at it`s hights. I wewre close to build it but didn´t. I am very interested in your oppinion on the sound on this one. Mark Alexanders article is very interesing indeed. Regards
Henrik |
#7 |
I helped a friend in the 80's and the output stage used MOSFET's but I don't remember which type, could have been IRF some type which ELFA had.
I never got a chance to really test this amp but it measured and behaved good. When somebody is used to certian sound and them tries something new it's hard to say what the problem really is. Thin base and good high range may also be an indicator of that the normal amp has bad treble performance. Deep bass (technically) isn't a problem because the amp is totally DC connected. Bass down to 0 Hz is possible without a problem. So at the moment I have a neutral attitude towards the Alexander amp. Current feedback is interesting and I will dive down more into the subject. I have found lot's of info on the net. BTW: I have also got the real original article from the AES.
#8 |
opa-277? very low offset, Iq < 1 mA , Ib quite small.
elfa. 73-387-59 I was also considering building this amp (according to the HF articles) until I heard about how many who had problems with the output stage oscillating and sourcing the output transistors. could also have been due to the fqact that the output stage was connected to the main board with wires e t c... Anyway, I have also seen a 200 W version of this amp with IRF 640/9640 in the output somewhere on the net, some years ago. ¨ I am almost 100 % certain I have the schematic printed (IRL ) on paper... /rickard
listen! Can you hear that ... |
#9 |
Do you mean this?
http://homepages.strath.ac.uk/~cnbp111/amp1.html OPA277 can be something, not so expensive either. The Alexander amp is a high speed design so I think the physical design is really important. No hard wiring!
#10 |
Wow! Someone actually building the Alexander amp.
I'm waiting with baited breath to hear your reactions. Patent: You need no permission from ADI to build this amp as long as it's not "commercial". I believe that they expressly give permission for any person to build one for their own hobby use. Servo amp: Low quiescent current is important as you want the main op-amp to modulate as much of the current in the current mirrors as possible. That's why the OP97 was chosen. Main op-amp: The SSM2131 was SSM's "improved" version of the NE5534, designed for high end pro audio equipment. If I were to build one of these, I'd consider an OPA627 or AD8610, etc. PCB layout: Alexander's paper has a very small and tidy PCB layout; one board for the low-level stuff and the other for the output devices. Also, good hints for physical layout and routing of power wires -- same stuff that Doug Self recommends. BTW, "SSM" stands for "Solid State Music", a small audio- oriented semiconductor company that PMI ("Precision Monolithics, Incorporated", for you youngsters) purchased shortly before ADI purchased them. Does anyone know the wereabouts of Mark Alexander?
bel |
| opamp for DC servo | lucpes | Solid State | 10 | 11th August 2004 10:33 AM |
| Adcom gfa-585 dc servo opamp | georgehifi | Solid State | 16 | 1st November 2003 01:50 AM |
| Schematic for Servo opamp. | sonnya | Solid State | 17 | 26th July 2003 04:38 PM |
| one-shot dual opamp suggestion | dorkus | Parts | 4 | 21st May 2002 05:59 AM |
| Page generated in 0.12898 seconds (78.12% PHP - 21.88% MySQL) with 10 queries |
