#11 |
Per:
>The Alexander amp is a high speed design so I think the physical design is really important. No hard wiring!< If you combine hardwiring (component leads only, no separate wires) with low-impedance ground and power planes, and design a tight layout, you can make some pretty high-bandwidth circuits. I've designed and built all-discrete 600MHz amplifiers like this. If anything, I find it easier to go faster using 3-dimensional circuit structures rather than keeping everything on the pcb (2D). A calculated mixture of smd, leaded board and 3D also works well, and is how I normally design. hth, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com |
#12 |
I have also build this amplifier a year ago with six pairs of IRFP240
and IRFP9240. The driver transistors are ultra fast BF758 and BF762 they have bean used in tv as uhf amplifiers, i think they are discontinued. I have used OPA604AP from Buur Brown as gain stage instead of SSM2131. I did not use DC servo beacose offset was always beatwin +/- 30 to 50mV.You have to place trim pot beatwin pins 1,5 for offset triming. i dont know why peaple say that amp oscilates, its very stable i also didnt use zobel network its not nesesery this is high bandwith amp,and you dont want to put low pas filter in the output. you also must take care of grounding of the driver board,i did had a problem with input left open it is very sensitive beacose input capacitor(750pF) is a filter which make this amp goes to 1MHz. The amp is unbelivably fast(transient reasponse) if you put some CD with acustic gitar or piano or some pasage with some good solo drums it realy scare you. The amp reali have total control of the speakers, if you never heard amp with high bandwith and high slew rate(250V/us)then you peaple dont know what you are mising. i wil send some foto's in a few days (driver and power print). I am also suprised how few peaple have build this amp. |
#13 | |
Account Disabled
Why do you find it necessary to design such a wide bandwidth into your audio amps.? mike. |
| opamp for DC servo | lucpes | Solid State | 10 | 11th August 2004 09:33 AM |
| Adcom gfa-585 dc servo opamp | georgehifi | Solid State | 16 | 1st November 2003 12:50 AM |
| Schematic for Servo opamp. | sonnya | Solid State | 17 | 26th July 2003 03:38 PM |
| one-shot dual opamp suggestion | dorkus | Parts | 4 | 21st May 2002 04:59 AM |
| Page generated in 0.08171 seconds (70.21% PHP - 29.79% MySQL) with 10 queries |
