#281 | |
Hi hitachi_nut, yes you were the first who suggested capacitor leakage issue and for that you deserve all credit and my gratitude. My only fear is that not only caps are the culprits here. Only reason for me thinking that way is because the amp was silent for more then six months after recapping, if the caps were leaking wouldn't they leak from beginning, such was the case with C517, it leaked the most when freshly installed. Anyways, per your recommendation I ordered Panasonic caps ECQV1 in 1uF/63V value so we can exchange C505/C506 and C527/C528, I recall you mentioned they are small in size, do you perhaps know exactly how small, those MKT were a tight fit so just to know what to expect when Panasonics arrive. |
#282 |
My wife informed me that the Panasonic caps finally arrived
My wife was also kind enough to send me this picture, I am at work, so in preparation to install them I have a few questions. From the picture it looks like lead space is pretty wide, Mooly you suggested drilling the pcb instead of bending the leads. Since I have never done such a thing I practiced a little on some pcb pictured below. I understand I should expose bare copper but how do I improvise the "eyelet", soldering post that is. Track in the picture is pretty wide so "eyelet" in this case is probably unnecessary, but I presume that the tracks in my amplifier are probably thinner. Inputs very welcomed here |
#283 |
Gently scrape off the coating over the copper strip.
Apply a hot iron and cored solder to the freshly cleaned copper surface to thinly tin the strip with the holes. Insert the legged components from the other side. Solder each components leg to it's respective strip (pad).
regards Andrew T. |
#284 | |
and thanks for quick reply. So I should carefully tin around the hole before inserting the cap? One more, I presume I can but just to be sure, can I use one original existing hole and add another, new one which is drilled further apart then the second original hole? It is a complicated sentence |
#285 |
your newly drilled holes are quite close together. Just tin the whole strip. Don't try to create a tinned pad around each hole.
If you had a single isolated hole, then it is worth exposing a small clean copper area to create a single pad. Soldering the pad areas (strip) before you attempt to attach the components will make the attachment much easier and less likely to damage the components and less likely to damage the glue joint from copper to substrate.
regards Andrew T. |
#286 |
The green solder resist just scrapes off. Try a sharp craft knife.
If the tracks in the amp are very thin then to avoid damage drill the hole next to the track without actually drilling into the copper. Then scrape the resist from the track alongside and insert the component lead and bend it to the newly cleaned track and solder.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#287 |
Thank you both for your advices.
Seems doable and hopefully I will report here tomorrow that C505/C506 and C527/C528 has been changed to Panasonics so we can continue debugging this amp. I sincerely hope this is the end of LN cap replacement |
#288 |
Your not the only one
#289 |
#290 |
The caps were a lot smaller in person then the picture suggested and the color of them is such that they blended perfectly in the Rotel interior, thanks for recommendation hitachi_nut
I drilled new holes the for leads and that went smoothly, although I would like to add one more advice to those already made by AndrewT and Mooly, and that is to check for any resistor crossing the track to be drilled on the top side, I was lucky To summarize C505/506 and C527/C528 have been changed to Panasonic ECQV 1uF, C517/C518 to ERO VISHAY MKT1826 4.7uF. Everything that was unsoldered before for testing purposes is soldered back, except of course volume pot and C505 and C506 are still tied to ground via point E7. Is it (tea) pot time now? |
| dc coupled volume pot value | nightanole | Tubes / Valves | 0 | 7th August 2011 09:38 PM |
| single push volume pot, volume up/down via a button. | dragonxwas | Analogue Source | 4 | 2nd June 2011 06:56 PM |
| Valve buffered IGC - volume pot causes DC offset, crackling | gaplessophile | Chip Amps | 29 | 3rd July 2009 12:02 AM |
| Volume control : - pot' or pot' variable feedback resistor (gain) ? | ash_dac | Solid State | 5 | 1st August 2006 05:07 AM |
| Gain pot instead of volume pot | boyofwax | Solid State | 5 | 14th February 2004 02:37 AM |
| Page generated in 0.11626 seconds (80.13% PHP - 19.87% MySQL) with 11 queries |
