Class H switching
Class H switching
Old 20th December 2011, 02:33 PM   #1
clovi_kate is offline clovi_kate  Philippines
Send a message via AIM to clovi_kate Send a message via MSN to clovi_kate Send a message via Yahoo to clovi_kate
Default Class H switching
hi guyz..
I have a question about class h amps having a mosfets switch. At time when amp is at full state (maximum operation), does the voltage across drain to source of mosfet reaches zero? (Vds=0)?.. And when the mosfets starts to switch to the voltage, does it increase the voltage slowly or it will switch to its highest voltage right away?..
Old 20th December 2011, 05:23 PM   #2
I have a question about class h amps having a mosfets switch. At time when amp is at full state (maximum operation), does the voltage across drain to source of mosfet reaches zero? (Vds=0)?.. And when the mosfets starts to switch to the HIGH voltage, does it increase the voltage slowly or it will switch to its highest voltage right away?..
Old 21st December 2011, 12:08 AM   #3
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
There are some differences when the mosfet turned on. The simplest one the mosfet just switched on when comparator say "go", and amplifier supply voltage increasing to the higher rail as fast as possible. The other one, there is a slew limiter so the voltage increases with limited speed/slew. Some other with early switch on and off with slew limiter.
Mosfet has its Rds-on when turned on, so there will be small drop voltages, around 1 volt.
Old 21st December 2011, 01:21 AM   #4
shal we say we have a rail of +-55V and +-110v and uses 15v early before the mosfet switch on. if the output voltage reaches shall we say 46Vp, mosfet will go 'on' and Vds has a voltage not equal to 1V. (with the pinch off voltage considered 4v)
so WHAT IF in this condition the 2 mosfets (+ and - rail switch) did not fire equally, resulting +Vrail and -Vrail shall we say +65v and -75v. does this condition will affect the dc offset of the amplifier because unbalanced rails?..
Old 21st December 2011, 01:50 AM   #5
djk is offline djk
R.I.P
djk's Avatar
"does this condition will affect the dc offset of the amplifier because unbalanced rails?"
No.
Candidates for the Darwin Award should not read this author.
Old 22nd December 2011, 08:31 AM   #6
ontoaba's Avatar
Supply voltage only switched at output stage, and VAS always connected to highest rail, and opposite mosfet stay off when a rail switched.
This is a multi step classH with slew limiter and early on/off for high speed operation (around 10kHz). Also higher voltage margin for higher step, because OPS has more drop voltage when draw more current.
Class H switchingHide this!Advertise here!
margan : non switching class B sreten Solid State 16 22nd May 2011 04:43 PM
Class AB, Class AB Non-Switching, Class AB Soft Non-Switching steph_tsf Solid State 4 15th March 2010 03:39 PM
New class A biasing (with non-switching class AB overflow) Steven Solid State 34 24th March 2007 06:40 PM
switching class d amp steven344 Class D 10 20th November 2005 03:22 AM
Non-switching amp same as Class A? mjarve Solid State 2 26th June 2004 07:43 PM
