I need to make a X5 preamp to boost a signal after some volume and balance controls and send it off at a nice low impedance to a power amp. It needs to be happy running off a single 12 volt supply.
I thought google or ebay would throw up something but so far I have not had any success. Does anyone have a circuit to share, it need not be fancy, transistor or IC, inverting or non inverting will do. Variable gain would also be fine as long as it included around 5 times in its range. I can make stuff but not confident enough to start from scratch. Cheers, Tim |
#2 |
Something like this would work. Change C3 to 100u and reduce R4 to 2K4 for 5x gain.
However note that if your input signal is more than 700mV p-p it will clip due to the limited swing of the opamp (about +/-4v with the NE5532 shown on 12V supplies). To get more headroom you would need a higher supply. You should be able to do this on stripboard easily. edit: Oh, if you like bass (this for a car amp?) then make C2 at least 33u. Last edited by jaycee; 18th December 2011 at 02:49 AM. |
#3 |
It will make a little more than 8Vp-p on the output at clip. That's more like 1.6 Vp-p on the input with gain at 5. Remember that's only a little .5V rms.
Personally I'd run a little higher feedback components to place less load on the output. 7K5 for R4 and 30K for R3 will get you the gain of 5 and still be reasonably low impedance. G² |
#4 |
Thanks guys, just what I was looking for. It is nearly for a car system jaycee, I use a car amp for a portable PA and have to use the -10dB outputs from the mixer. Creating a suitable output with controlls has cut down the output enough to limit the audio to the power amp so it needs this boost. A gain of 5 may even be excessive but controllable.
#5 | |
G² |
| X5 5ch ??? | ping_31140 | Pass Labs | 8 | 18th March 2010 05:21 AM |
| Looking for a X5! | ssabripo | Pass Labs | 0 | 24th February 2010 08:45 PM |
| BMW X5 tv tunner no DVD | GUS | Car Audio | 0 | 10th May 2004 03:33 PM |
| FS: Ortofon X5-MC phono cart. BRAND NEW | Doctorcilantro | Swap Meet | 0 | 2nd April 2004 07:27 AM |
| Philips DAC TDA1541A-R1 x5 | frenzic | Swap Meet | 0 | 7th September 2003 07:52 PM |
| Page generated in 0.07685 seconds (74.61% PHP - 25.39% MySQL) with 11 queries |
