Class i and siblings
Old 30th December 2011, 08:34 AM   #81
padamiecki is offline padamiecki  Poland
Originally Posted by dadod View Post
...Yes I would like to use it with tupbe pre and no global feedback, ...Damir
I was interested this because of the same reason
regards, Pawel
Old 30th December 2011, 09:45 AM   #82
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by Edmond Stuart View Post
Hi Damir,
But what happens in case of square waves or a sine of say 250kHz? An ideal OPS should show the same (low) cross-conduction, though that's not always possible.
E.
Hi Edmond,
Here is square waves test at 5k, 100k, end 200kHz.
It is still with my input stage, GNF, and input filter. What do you say about it?
Damir
Old 30th December 2011, 12:34 PM   #83
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Hi Damir,
It doesn't look good.
edit: In the meantime I tried to make the high impedance low offset version working,
but I'm still experiencing troubles: above 100kHz, let alone square waves, it goes berserk.
So I give up and try to improve the original version of AB2.
Regarding to offset, you might use a DC servo to zero both voltage and current offset.
What about that?
E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het lichtů(H.M. van Randwijk)
Old 30th December 2011, 12:47 PM   #84
Originally Posted by ontoaba View Post
BTW: not good to call another is idiot just because feel genius, because it is bad for people relation.
Not my words. Instead, I was talking about 'Einsteins' and 'smarty pants'.
E.
Old 30th December 2011, 01:09 PM   #85
dadod's Avatar
Hi Damir,
What about that?
E.
Hi Edmond,
Do you mean to use a DC servo for AB2 as OPS for tube preamp, or AB2 used in all bipolar amp with GNF? I am interested in both, thermal and bias stability is annoying with standard bias spreader even if TT transistors are used.
Damir
Old 30th December 2011, 01:20 PM   #86
Default mods
Looking at some modifications of my circuit, I got the impression that not everybody fully understand every detail of the AB2 circuit. Of course, those mods do work (more or less), but as they deviate too much from Class-I and AB2, I think it's more appropriate to post those circuits on a more general thread about sliding bias circuits. For example this one: Variable operating biass output ?
In order to ease the distinction between circuit which belongs to Class-I (and look-alikes) and those which do not, what about an (short) explanation of the basic principles of Class-I and AB2?
Any interest?
E.
Old 30th December 2011, 01:26 PM   #87
Default servo
Hi Edmond,
Damir
Hi Damir,
I mean a servo for the preamp version. Integrated with an all bipolar amp is another story. It depends on the input stage whether you need a servo or not.
E.
Old 30th December 2011, 01:45 PM   #88
dadod's Avatar
Any interest?
E.
This a great to explain all what is in those circuits, I am very interested.
Damir
Old 30th December 2011, 02:08 PM   #89
homemodder is offline homemodder  Portugal
Edmond
Nice results, could you direct me to Ken Peters paper, I must have missed it.
Who patented TMC ??? Something tells me it was probably had from this forum.
Seasons greetings to you and family and prosperous new year.
Old 30th December 2011, 03:02 PM   #90
Originally Posted by homemodder View Post
Edmond
Hi Homemodder,
Probably you mean Kendall Castor-Perry.
Anyhow, his paper has been published in Jan's Linear Audio Vol. 2.
Perhaps Jan is willing to scan 24 pages and send them to you
A patent of the same circuit can be found here: http://www.diyaudio.com/forums/every...ml#post2799107
Please, look here: Bob Cordell Interview: Negative Feedback
Thanks, the same to you.
E.
Class i and siblingsHide this!Advertise here!
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 07:49 AM
Collection of Class B topologies <100mA Idle and Sound closest by Class A tiefbassuebertr Solid State 37 27th July 2012 09:04 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 11:30 AM
Copyright ©1999-2017 diyAudio
