Class i and siblings
Old 16th March 2012, 11:49 AM   #201
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Hi Keantoken,
I appreciate you have figured this out.
I also share your concern about the quasi-saturation and how well that is modeled.
Vce of Q5 & Q6, for example, is very low. Happily, these trannies have little work to do, as they only provide the bias voltage for the other trannies (Q3, Q4, Q7 & Q8).
BTW, how well matched are those NXP duals? They are not monolithic, is it?
E.
http://www.data-odyssey.nl/
Old 16th March 2012, 07:24 PM   #202
keantoken is offline keantoken  United States
keantoken's Avatar
I have not tried the duals, they are not advertised as matched so I can only assume they are like transistors from the same batch. I heard that Phillips BC560C had very good matching straight from the factory, but they no longer make those and Phillips has become NXP.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 3rd October 2012, 10:00 PM   #203
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
For those (still) interested in class i, Kendall's original Linear Audio article is being published by EDN in their 'analog zone'.
Part I appears here:
Designing a low-distortion audio output stage - Part 1: Introduction, the problem with push-pull outputs | EDN
Enjoy!
jan didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 23rd May 2013, 02:40 PM   #204
Bigun is offline Bigun  Canada
Bigun's Avatar
I notice that Pioneer had Class I technology in the past and yet as far as I can see they do not use it in their products today.
Are there any subjective reports of sound quality comparing Class I with the simpler double EF output stage ?
And I have the impression that the Circlophone approach is equivalent in many ways and reports are that it sounds very good.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 24th May 2013, 01:58 PM   #205
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
Psst.. no cimpiraibli i using ears...
if you looking for earable comparison try another one like this DOT. It is comparable with SE 805 + 300B configuration. Even better in treble(high).
But class i+siblings really are fun and interesting for engineering, marketing and visual comparison. Indeed..
File Type: png hexfet source follower single ended censored.PNG (66.7 KB, 317 views)
Old 2nd August 2013, 12:18 PM   #206
Waly is offline Waly
Default Experiments
Edmond's BFF, syn08, is experimenting with autobias schemas, comparing various non-switching arrangements (from the Linear Technology LT1166 to optocoupler drivers, including Kendall's Class I, Edmond's cloned LT1166 autobias schema, etc...) in terms of long and short term thermal and HF stability, distortion performance, integration with various front ends, etc...
Results with Edmond's autobias are, so far, mixed. The THAT Spice models are as bad as the next, so some changes in the original design are required to make it work. Other changes are required for stability, including managing a nasty RHP zero that is otherwise killing the gain margin when a global NFB loop is closed.
Unfortunately, I am not at liberty to further discuss his stuff here. Edmond or anybody else interested in this stuff may contact him directly.
Old 7th December 2013, 08:34 PM   #207
Petr1951 is offline Petr1951
Despite the high complexity of the output stage of class-i works well on resistive load, the distortion at 1 kHz, no more than 0.005% at 30 V (peak) output.
At the same time he did not hold the external load and external load distortion increased more than 100 times (to 0.8%), which in my opinion is not suitable for audio amplifier.
best regards
Petr
Class i and siblingsHide this!Advertise here!
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 75 3rd December 2016 06:49 AM
Collection of Class B topologies <100mA Idle and Sound closest by Class A tiefbassuebertr Solid State 37 27th July 2012 08:04 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
