Old 22nd December 2011, 04:56 PM   #41
Edmond Stuart's Avatar
Default push-pull drivers
Originally Posted by dadod View Post
Hi Edmond,
Could you show the circuit?
Damir
Hi Damir,
Here it is. Red encircled are the PP-drivers and left to the 1X buffer the 2nd order LP filter. (btw, this amp is not complete).
With this synthetic 1x buffer you can push the amp to much higher slew rates. But, as said already, not without dangerous cross-conduction.
If you put the LP-filter in front of the pre-amp, it has to modified (of course).
E.
edit: The crux is the crosswise connection of R23 & R24.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het licht…(H.M. van Randwijk)
Old 22nd December 2011, 06:51 PM   #42
dadod is offline dadod  Croatia
dadod's Avatar
Originally Posted by Edmond Stuart View Post
Hi Damir,
E.
Hi Edmond,
It looks great, I will try it in my simulation soon.
Damir
Old 22nd December 2011, 07:56 PM   #43
Default Filter
Hi Damir,
In case you incorporated also a front-end (with a gain of 28x), here's the modified LP-filter.
Hope it works; good luck. FYI, it's a Sallen-Key filter.
E.
Old 22nd December 2011, 09:53 PM   #44
And for those with an adventurous mind or those who detest thermal NBF, here's another version that does away with thermal coupling of the PP-drivers and the bias spreaders.
edit: not recommended.
E.
Old 23rd December 2011, 06:33 AM   #45
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
Yes. It (auto biased) work with 3906-3904.
Good slew rate but 9540 is just big gate caps charged with only 34mA.
Input is light error corrected and FFT around 0.004%THD all freq to 20k.
Old 23rd December 2011, 07:06 AM   #46
dadod's Avatar
Hi Damir,
E.
Hi Edmond,
Thermal fluctuation of the PP drivers will not influence thermal stabillity of the output transistors, I suppose?
Damir
Old 23rd December 2011, 08:57 AM   #47
ontoaba's Avatar
May be I am doing wrong, I need pre EC to correct voltage gap and it work with 4148 too.
Hi, Damir.
Output stage is never turned off, up to 20kHz (my pict), looks like output transistor bias determined by AB circuit not heatsink temp.
Old 23rd December 2011, 09:55 AM   #48
Hi ontoaba,
Amazing that even a minimalistic implementation, like yours, does work.
Nevertheless, I urge you to insert push-pull drivers between the bias circuit and MOSFETs (because of high Cgd and Cgs).
E.
Old 23rd December 2011, 10:09 AM   #49
dadod's Avatar
Hi, Damir.
Hi ontoaba,
Nice implementation. I know how AB works from simulation Edmond AB2 and Kendall Class i.
Damir
Old 23rd December 2011, 10:40 AM   #50
Hi Edmond,
Damir
Hi Damir,
That's correct. Iq of the OPS is firmly stabilized by the high DC gain of the common mode NFB loop (51dB), see 1st pic.
The 2nd pic shows the differential loop gain and phase. This NFB loop determines to what extent the distortion is reduced.
The wild phase fluctuation at 100MHz worries me a bit, but I don't know (yet) how to tame it. Also, I don't know if it is really harmful.
E.
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 19 3rd May 2013 05:31 PM
Collection of Class B topologies <100mA Idle and Sound closest by Class A tiefbassuebertr Solid State 37 27th July 2012 08:04 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 10:30 AM
Copyright ©1999-2013 diyAudio
