I just killed my amp - please help me!
Old 14th September 2003, 01:27 PM   #1
schnitti is offline schnitti  Germany
Default I just killed my amp - please help me!
Hi everyone,
I was just making an attempt to measure the bias of my amp , and by accident short-circuited the right-channel
output with VCC+ ( 32,6V).
Now, you might think it's his own fault or what an amateur, but maybe you could have a look at the atteched schematic and give me some advice which parts probably are broken (I have marked the point in the schematic).
I would be very glad if someone could help me!
schnitti
Old 14th September 2003, 03:32 PM   #2
Eccu is offline Eccu  Finland
Eccu's Avatar
Hmmm... what schematic?
right way boy... u sold farm and bougth booze
Old 14th September 2003, 03:45 PM   #3
New attempt
Old 14th September 2003, 05:28 PM   #4
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Are you sure it is not just the fuse???
It's difficult to se details on your posted schematics....
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 14th September 2003, 07:13 PM   #5
Hi ACD,
yes, the fuse blew too, but I think that's not the only part which has to be replaced. I guess that the output transistors are broken too (2SB1383 / 2SD2083). I attached a bigger detail of the schematic (only left channel), maybe you could have a look.
Thanks,
schnitti
Old 14th September 2003, 07:32 PM   #6
Jan Dupont's Avatar
Have you actually replaced the fuse or meassured (comparing one channel to the other) that more has been damaged?
Old 14th September 2003, 09:43 PM   #7
First after having short-circuited the amp, it was in a "safe mode". I turned it of (main switch), waited a few minutes and then turned it on again. In the same moment the main fuse blew. So I'm a little bit helpness at the moment. By the way it's a small integrated amp from Denon (PMA-201SA).
Old 15th September 2003, 01:22 AM   #8
mcp is offline mcp  United States
My guess is it is unlikely to be in the gain stage. You probably blew either one of the driver, output or both. Since it is a small integrated amp, the drivers and outputs can be easily replaced. It is also a good idea to change the associated emitter resistors as well.
Michael Chua
Old 15th September 2003, 03:00 AM   #9
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
I blew up the pic in corel draw and I would replace the associated resistors and output transistor but before you do that make sure the zener is regulating the base it could be bad
I just killed my amp - please help me!Hide this!Advertise here!
killed BJT zilog Solid State 4 28th May 2008 08:28 AM
Killed my T-Amp? JWFokker Class D 3 28th March 2007 07:54 AM
killed needle or something else? Nordic Analogue Source 11 2nd January 2007 08:14 PM
I think I killed it. Nappylady Chip Amps 28 11th November 2003 02:24 AM
Copyright ©1999-2017 diyAudio
