Ugh! Opened the case of my GFA-535 (bought back in 88 or 89) and the PSU board has a lot of brown gunk around the big 6800 um capacitors. Last time I opened it to clean and replace fuses, probably 5 years ago, I don't recall seeing that. I suppose this is the leaking capacitor issue? One reason I opened the case is that the woofer on my left channel speaker blew but I don't recall any bad behavior (well maybe from one of my kids). Anyway, I figured I'd look inside to check fuses and to see if anything looked odd. I obviously need to change the capacitors but how should I (or should I at all) clean the board? Any help appreciated.
#2 |
Electrolye is somewhat water soluble, so alcohol and cloth should remove it safely if you repeat the process until all remnants are removed - both sides and lurking in through-holes too. Use a brush to remove difficult stuff and try to avoid spills on unaffected areas and the case etc.
Test that solvents don't remove any printing on the PCB, as this will make troubleshooting very difficult. If this is the case, adding a little water to the alcohol will reduce this attack. Many other solvents like acetone will remove printing pronto - take care. Dry it out thoroughly in a warm area before fitting replacement caps and powering up again.
regards |
#3 |
Thank you Mr. Finch!
#4 |
That "Brown Goo" in not Lytic fluid. It's the glue that was used to help hold the device and shoud not be a problem. If you repalce the caps it would be from age but I would guess the caps are in good shape. Change them if you want, it may just be a waist of time unless you mesure them and find out there high in ESR and low in value.
| Adcom GFA-535 Transistor sub | Ardvaark | Solid State | 3 | 6th September 2011 01:41 AM |
| Adcom GFA-535 Settings | Ardvaark | Solid State | 2 | 16th August 2009 08:10 PM |
| GFA-535 Manual | Funkenstein | Solid State | 6 | 16th June 2009 01:26 AM |
| FS: Adcom GFA-535 | sdstarnes | Swap Meet | 3 | 12th February 2008 02:43 AM |
| GFA 535 right channel out. | sdstarnes | Solid State | 8 | 4th February 2008 03:07 AM |
| Page generated in 0.07904 seconds (73.17% PHP - 26.83% MySQL) with 10 queries |
