Old 15th December 2011, 02:31 AM   #1
Default Need schematic KEF 25B sub amp SP2298
I need a schematic for a KEF 25B subwoofer plate amplifier model SP2298.
Or a replacement plate amp cheap.
Old 15th December 2011, 05:44 PM   #2
This is about 100 watts, mono (transformer couldn't do more than that). Looks like 4 large tab/screw output devices, and 1 small device thermally coupled to the heat sink. There's a lot of heat discoloration around the crappy little power supply diodes, but that could be symptom rather than cause (or neither).
Old 15th December 2011, 05:47 PM   #3
Maybe I'll just close up the hole with a plate and make it passive, but I have no mixer or mono amp nor small bridgeable amp, and the voicecoil is not a dual coil.
The surround is intact, but it feels like the type of foam that gets a bit sticky before it crumbles completely. Stamped frame. I'm not impressed.
I guess what I have is one bass-reflex box for a 10". Just what I never wanted. And I paid $50 for it. There's another on eBay with the exact same problem (blows fuse), but then shipping makes it unreasonable. Unless repairing the pair on amps would become cost-effective.
Old 6th January 2012, 07:14 PM   #4
Anybody want to fix it for me for a reasonable fee?
Old 10th February 2012, 06:06 PM   #5
Any good ideas?
Old 27th February 2012, 06:13 AM   #6
Getting desperate. I no longer have the equipment to do this myself, but I suspect I could replace the powersupply rectifier diodes and all the output tansistors for much less than getting a new plate amp.
Old 15th March 2012, 05:10 PM   #7
Anybody got "connections" to get the schematic for this plate amp from KEF?
Old 21st March 2012, 08:47 PM   #8
Nobody?
Old 26th March 2012, 12:50 PM   #9
Can you post the static ohms of your driver. Mine must be shorted because it checks at .2 ohms. I have not been able to locate any source of a schematic. Mine is blowing the AC use. Mine also has the discoloration on the board at the diodes.
KEF PSW 2150 Need Schematic skeoch Subwoofers 10 11th January 2012 12:22 AM
Kef PSW2000 Sub schematic required 405man Subwoofers 66 17th July 2011 11:15 PM
Coral 12L-25B Jameslc Subwoofers 0 30th March 2011 11:22 AM
Kef R105/3 Kube equaliser schematic jez Multi-Way 64 21st March 2011 01:00 AM
KEF 104B crossover schematic needed ! promitheus Multi-Way 17 9th January 2009 09:30 PM
Page generated in 0.08149 seconds (76.37% PHP - 23.63% MySQL) with 10 queries
