Old 12th December 2011, 05:28 PM   #1
errcl65 is offline errcl65  Canada
Default Replacement Transformer for Quad 405
When can I source in North America, an
affordable 115V / 300VA Toroid with 2 x 35VAC
what will fit in the original Quad 405 chassis?
I've got a unit here with a very noisy main.
Old 12th December 2011, 06:17 PM   #2
Mooly's Avatar
Can't help you with local suppliers I'm afraid but have you considered it could (might) be a mains purity issue.
Mains DC and Transformers
A simulation free zone. Design it, build it, test it.
Old 12th December 2011, 06:58 PM   #3
not sure if you know but the Quad uses a C-core transformer. I would look for a used 405 for the parts. Best regards Moray James.
moray james
Old 12th December 2011, 07:38 PM   #4
jez is offline jez  United Kingdom
There was a batch of noisy mains transformers that Quad had problems with during the 70's. It could be you have one of them...
Repairs and mods to Real Hi-Fi, guitar amps and P.A. in North East England. http://www.arklesselectronics.com
Old 12th December 2011, 09:30 PM   #5
When the unit is cold, it is quiet. After about 15 minutes, the transformer
will start to hum/buzz. It isn't from the AC as I have had it hooked up
to AC/DC - DC/AC isolation unit APC R1500 which give is a clean 60Hz.
This particular Q 405 looks to be of an early vintage.
On the net, there are some toroids from Multicomp, but they only
have 230 V primary side. No good for North America.
Old 13th December 2011, 06:52 AM   #6
Mooly's Avatar
Multicomp split primary,
MULTICOMP|MCTA300/35|300VA TOROIDAL 2X35V | CPC From This Range
Is it worth a dip in varnish for the old tranny. Heat the tranny up first (quite hot say around 60c) and then immerse in varnish for an hour or two, remove and leave to drip dry for 24 hours. Then place in a warm location.
Old 13th December 2011, 08:02 AM   #7
Ian Finch's Avatar
Did you try these guys or other links from Hammond Mfg.?
Toroidal Transformer Sale, Toroidal Transformers on Sale!
regards
Old 13th December 2011, 06:15 PM   #8
sregor is offline sregor  United States
antek Antek - Your reliable source of transformers, power supplies, and more.
Steve
Quad 405 Piersma Swap Meet 8 25th October 2011 03:23 PM
quad 405-2 goodguys Solid State 3 14th March 2011 09:35 AM
Quad 405 mains transformer? Confussed Solid State 2 14th August 2007 06:12 PM
pcb for quad 405 kanjumi Solid State 6 3rd April 2006 05:03 PM
quad 405 hazenhoe Solid State 2 27th December 2003 01:32 AM
Page generated in 0.09229 seconds (77.38% PHP - 22.62% MySQL) with 10 queries
