Here is my first attempt on amp design. Instead of making a completely new design, i used "optimos" by randy as base and started fitting in my requirements. Based on Bob's book on amp design, i've redesigned the output stage with Vertical fets and changed the Compensation from TPC to TMC. Also few component values are changed to enhance slew rate, stability etc.,. I've acheived a THD-20 as 0.014% at Max. power.
Any comments...? |
#2 |
I'd like to check it out. Could you post the LTspice .asc file?
#3 |
LTSpice file
#4 |
Any one else ....comments / suggestions...?
| noise problems with an OptiMOS | sinigersky | Solid State | 10 | 19th August 2011 04:26 AM |
| About optimos pcb | CHRIS DIAMONDS | Solid State | 0 | 16th August 2011 08:00 PM |
| Optimos Question - Circuit | 1965GTO | Solid State | 2 | 16th September 2010 06:27 AM |
| Finished my optimos amp! | whalefat | Solid State | 0 | 18th April 2005 09:51 PM |
| OPTIMOS-Amp from Randy Slone | wopo | Solid State | 1 | 12th July 2004 08:18 PM |
| Page generated in 0.08419 seconds (71.27% PHP - 28.73% MySQL) with 11 queries |
