| View Poll Results: Did you build or buy. Why? | |||
| I built my own. [Please answer why below] |
24 | 88.89% |
| I bought my own. [Please answer why below] |
0 | 0% |
| I have no idea, I just like to vote. |
3 | 11.11% |
| Voters: 27. You may not vote on this poll | |||
I would like to see the advantages of building over buying.
From what I read, its basically a more direct/pure signal as there are not as many checks (thermal, short circuit protection, etc). Why did you build your own over buying one already made? |
#2 |
do you mean more unreliable, dangerous to your speakers, possibly to your health and safety from skimping on electrical and fire safety measures?
at the "lower" end of the cost, perceived quality scale mass manufactured amps are cheaper than you can buy the raw parts for as an individual good deals can be found on "intermediate" used amps from big consumer names - Earl Geddes has done research on amp distortion audibility, published in the JAES he uses a Pioneer amp for demoing his custom waveguide speakers - clearly he believes the amp isn't compromising the sound if you want a hobby and are willing to accept the higher costs for uncertain, possibly imaginary results then you can "play" with various audiophile fads, pretensions |
#3 | |
Cost. Significant savings may be achieved in home-constructed equipment, especially when recycling old hardware. Disused or faulty amplifiers often have usable cases and working transformers, connectors and heatsinks (amongst other parts). These may be found online for next to nothing and can save the constructor from much of the mechanical work. The more skilled constructors may elect to build everything from scratch including the panels. One way or another, it shouldn't be too difficult to build fairly presentable-looking equipment for just a modest outlay. Performance. Well-constructed equipment following a proven design (many of which are available on this forum) will often exceed the performance of commercial products costing many times more. The experience. Building and commissioning your own equipment will teach you a considerable amount: Design, construction, fault-finding, etc. Pleasure. The satisfaction of owning and using a home-made amplifier which performs well cannot be underestimated! Experimentation. As for the signal purity, the constructor will be presented with many design options - some tried and tested, some cutting-edge and relatively unproven. Whether short-circuit or other protection is incorporated or not will depend on the risk the constructor is prepared to take versus their quest for the most direct signal path. It's all about choice. Regards, currentflow |
#4 |
Building an amp can get quite costly, especially when experimenting or when things don't go as planned. However, there aren't too many people who can say they built their own amps and you have a lot of control over the quality and construction to suit your needs..
Really the only way it can be cheaper is if you go with cheaper parts, which might be fine. Manufacturers buy in such bulk that they can get the expensive stuff we want at really low prices. |
#5 |
Most of the diy amps made here are way better than many commercial ones. Most commercial ones are low in build quality and parts as well. and do not forget here at diyaudio.com there are some excellent and well known amp designers/builders that help you building very good amps. Building your own amp for sure is a wonderful feeling!
#6 |
#7 |
yes!, and also in quality of the parts that people use. in my case I use in my power supply Mundorf audio grade caps 125c. There are not many commercial amps that use Mundorf audio grade caps in their power supply. if you find one they are going to charge a lot!!!! just one cap is about $30 and some people use several or so. some people say all parts are the same...I do not think so!!!. But of course you will find some diy amps that sound like crab!.
This is from Mundorf site at partsconexion. The Black (Titanium) Cathode coating is remarkably impressive at both measurements and music performance. The Titanium coating replaces the ordinary aluminum oxide coating (dielectric) in order to avoid the electrolyte being the cathode for the anode foil and, that the electrolyte operates as anode for the aluminum contact foil, simultaneously. Our Black Cathode electrolyte capacitor really does feature a separate cathode foil enabling super fast and almost loss free ion movement for reduced ESR, distortion and 'noise' to the utmost lowest level. These positive effects are similar to (but much stronger) graphite modified electrolytics (like Black-Gate). With the MLytic® Audio Grade series we are extending our range of products to a series especially conceived for applications within pre-amplifiers or small power amplifiers. The assemblage always refers to snap-in models for assembly boards. Throughout its development, importance was placed upon attaining low ESR and ESL values, as well as, a low inner-sound development. Specifications: - Long lifespan - All contacts welded - Compact size http://www.partsconnexion.com/prod_pdf/mund_ag.pdf Last edited by lanchile; 7th December 2011 at 08:29 PM. |
#8 |
then where are the measurements?
I like to see comparative measures too - whats your "reference" amp? |
#9 | |
2sk1058 2sk2221 irfp9240 mosfet amplifier schematic |
#10 | |
PS: to be a diy amp it is not so ugly (I think). Last edited by lanchile; 7th December 2011 at 09:15 PM. |
| FS: Building Valve Amplifiers by Morgan Jones | Looneytunes | Swap Meet | 2 | 27th February 2010 08:31 PM |
| How to self taught about building tube amplifiers | fallot | Tubes / Valves | 10 | 22nd January 2010 05:19 PM |
| Building or buying? | Zac_cutt | Car Audio | 0 | 27th May 2006 11:32 PM |
| What would be better: buying a cd player or building one with a transport? | Bricolo | Digital Source | 182 | 27th January 2004 12:13 AM |
| Completely new to building amplifiers | TStrong_06 | Tubes / Valves | 66 | 24th December 2002 08:45 PM |
| Page generated in 0.12524 seconds (83.89% PHP - 16.11% MySQL) with 12 queries |
