Roender's FC-100 prototype and builder's thread
Old 6th December 2013, 06:29 AM   #871
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Paul, I do not know any suitable polypropylen capacitor either.
I am either using polyester capacitors (for example: VISHAY MKT1822) or WIMA MKS4, which uses a PET foil.
Best regards - Rudi_Ratlos
Old 6th December 2013, 02:30 PM   #872
R.I.P.
Originally Posted by wineds View Post
What is the best option for the input DC blocking cap? It should be 3.3 to 3.9uF according to Andrew? ........
I have gone back through all the last 220posts.
Can you refer me to the post.
regards Andrew T.
Old 6th December 2013, 08:54 PM   #873
wineds is offline wineds  Australia
Thanks Rudi!
Old 6th December 2013, 08:54 PM   #874
Hi Andrew, I was referring to this post in the original GB thread as cited in the builders manual :
http://www.diyaudio.com/forums/group...ml#post3160282
Old 7th December 2013, 09:21 AM   #875
R.I.P.
OK, now I see.
The time constant around 85ms to 100ms suits me. But it must also suit the abilities of the amplifier.
That was the point I was making.
Stating capacitance alone without the resistance value tells us nothing. It's a filter and both parts of the filter require specification.
regards Andrew T.
Old 22nd January 2014, 08:39 AM   #876
atupi is offline atupi  Romania
Solved bias issue by exchanging all the 0281/0302's. I was complaining last year about my bias was rising slowly with temperature and becoming suddenly unstable.
I have discovered that my transistors has some diode problems also quite high Vfe. The old ones has Vfe diode around 0.520V and the new working ones are very close to 0.500V.
It seems that Onsemi has some problem in the past with thermaltrack diodes.
Old 3rd April 2014, 11:15 PM   #877
Originally Posted by andreasw View Post
@atupi
On the picture you can see how it works.
I took 2 Conrad heatsinks (350x150x60mm), 8 Aluminum angles and a plate of 3mm Aluminum.
The plate doesen´t reach the heatsinks there is a 10mm slut.
With the holes in the top plate there is enough air circulation.
At first the amp has to play some hours.
Later I will write something about the sound in comparsion to an Aleph J and Symasym (at this moment ...).
Andreas
Andreas, can you please tell me where you bought the Aluminum angles?
Old 6th June 2014, 11:14 AM   #878
What is the consensus regarding loudspeaker protection? Do I need to use one with the FC-100?
Old 6th June 2014, 11:20 AM   #879
R.I.P.
If YOU consider your speakers as "expensive" then YOU decide if you want to protect them.
It has nothing to do with the amplifier type, nor it's design.
regards Andrew T.
Old 6th June 2014, 11:23 AM   #880
andreasw is offline andreasw  Germany
Excuse me that saw your question so late.
The Aluminum angles are self made (like everything of the case except the heatsinks).
I cut them of a big one in pieces of 20mm and drill the holes.
The first test I did with the speaker protection and later I took it out.
Andreas
Roender's FC-100 prototype and builder's threadHide this!Advertise here!
