Roender's FC-100 prototype and builder's thread
Old 8th April 2013, 05:55 PM   #721
roender is offline roender  Romania
roender's Avatar
MJE15035 looks good but MJE15034 seems to be very different from my transistors, direct samples from ON Semi. Maybe you have a fake transistor?!
Old 8th April 2013, 06:08 PM   #722
AndriyOL is offline AndriyOL  Ukraine
I did direct samples from Onsemi, however such hfe spread of mje devices seems depends on from country of origin. Chinese devices used to have such wide hfe spread, thus low quality production.
If for pristine and pure adoration - it's diyAudio dedication!
Old 8th April 2013, 06:11 PM   #723
atupi is offline atupi  Romania
Hi Mihai,
i have all my MJE transistors from Onsemi directly.
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 8th April 2013, 09:35 PM   #724
R.I.P.
Peter,
I think you may be measuring the change in hFE as Tj changes.
regards Andrew T.
Old 9th April 2013, 12:07 PM   #725
R.I.P.
Originally Posted by PeterLeest View Post
........The Hfe would increase a bit in each test (is it affected by heat ?). ...........
hFE is affected by Tj.
As Tj increases hFE increases.
But, I would expect similar increase for both NPN and PNP.
Your results don't show that NPN to PNP correlation.
regards Andrew T.
Old 9th April 2013, 03:45 PM   #726
PeterLeest is offline PeterLeest  Singapore
I did another test. Yes, the hFE increase is indeed similiar. BTW, I find Locky curve tracer is a very convenience and useful DIY tool.
Old 14th April 2013, 11:37 AM   #727
I finally fire up the board and the current readings are fairly close to Roender rating
Q17 collector 1.1 mA
Q13/11 collector 9.2 mA
MJE15035/34 R15 80 mA
Shunt read 39V & main is 36V. For basis, it started at 29C for 185 190 190 mA, and settled at 175 185 185 mA after heat sink heat up and stabilized at 45C, power TRs are 47C.
For the Shunt, MJE15034/35 run very hot at 53C, is there a problem?
For dummy resistive 8R load test; the square wave looks very good without ringing (1 KHz to 100 KHz). Then, I parallel a 1 uF capacitor to the load, I have oscillation, tune up power and fuse brown.
Whats next ?
Old 14th April 2013, 01:49 PM   #728
roender's Avatar
Whats next ?
You should insert in series with the output an 1...2uH air coil paralleled with some low ohm 2W resistor for supreme stability in any capacitive load.
For any real load this isn't necessarily unless you are using some very capacitive speakers.
Old 14th April 2013, 03:02 PM   #729
Rudi_Ratlos is online now Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Lee, the power dissipation of the shunt's MJE - transistors results from the output voltage of the shunt's transformer.
I myself am using a transformer with 34VAC secondaries, and my MJEs are not getting as hot as yours.
You have asked: what is next?
What about listening to the beautiful music that the FC-100 is producing?
Best regards - Rudi_Ratlos
Old 16th April 2013, 12:56 AM   #730
Hello, I did some testing for 8R resistor load at 20KHz. One channel is fine, another is overshoot, slower slew rate and non-linear. anyway to fine tune ? thanks for help. I haven't put in the output coil.
Roender's FC-100 prototype and builder's threadHide this!Advertise here!
