Roender's FC-100 prototype and builder's thread
Old 28th February 2013, 09:03 AM   #671
R.I.P.
Originally Posted by atupi View Post
Measured my 10pcs of NJL0281 i have:
Vf (diode)
0,503
0,510
0,510
0,509
0,509
0,509
0,504
0,507
0,506
0,507
At what test current?
Much more important to match the Vbe @ 185mA and ~hFE (+-5%) @ 185mA than to select for Vf.
regards Andrew T.
Old 28th February 2013, 10:24 AM   #672
atupi is offline atupi  Romania
I've attached the test rig recommended to me by Rudi and the testing current is close to the one recommended by you.
Vbe is pretty consistent and is ranging between 0.630 and 0.638V among the 10 transistors under test.
Hfe obtained after calculation was:
86,09
94,65
90,90
91,24
92,90
92,90
95,25
88,80
91,77
85,76
Now i wait some NJL0302 from a fellow diy-er from Poland to how they measure.
I have also some good matching pairs of 3281/1302 but i understood that they sound a bit different that the recommended 0281/0302.
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 28th February 2013, 10:33 AM   #673
R.I.P.
...........................Vbe is pretty consistent and is ranging between 0.630 and 0.638V among the 10 transistors under test...............
That is the really important parameter.
A 3pr output stage MUST have the three devices with very close Vbe
I consider +-1mVbe to be too high, a 1mV spread is preferable.
regards Andrew T.
Old 28th February 2013, 12:01 PM   #674
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
@PeterLeest: I am not aware that any of the small resistors has to dissipate more than .25W.
I use 1% metal film resistors manufactured by YAGEO (formerly: VITROHM), and these resistors are rated at .6W.
Best regards - Rudi_Ratlos
Old 4th March 2013, 05:37 PM   #675
For measuring Hfe of 15034/15035 is needed the circuit that i've attached above in #672 to have a higher test current ?
I'm asking this because i've measured them on my DMM and i have different ranges for PNP and NPN something like 120-170 vs 212-218 and i can't see any chance to select some pairs. I have 10 pcs of each.
Old 4th March 2013, 05:39 PM   #676
Telstar is offline Telstar  Italy
welcome to the world of "complementary pairs"
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 5th March 2013, 06:38 AM   #677
You where much lucky than me in finding matched 15034/15035 ?
Old 5th March 2013, 09:32 AM   #678
No, but i have had similar luck with other pairs. In short, You need 20+ pieces or more luck
Old 6th March 2013, 01:59 PM   #679
AndriyOL is offline AndriyOL  Ukraine
Can anyone help, what could be a reason of fc100 amp shorting after powering it up with 40W light bulb tester?
Used it with 30VDC main PSU and 37VDC fronted PSU. They are work fine alone.
If for pristine and pure adoration - it's diyAudio dedication!
Old 6th March 2013, 02:30 PM   #680
Andriyol, the power dissipated by a FC-100 channel in idle status is about 35W.
Add to this about 5W for the frontend shunt, and you will see: a 40W bulb tester is too small.
Moreover: please connect the bulb tester only to the backend, when you power-on both the shunt and a FC-100 channel.
Best regards - Rudi
Roender's FC-100 prototype and builder's threadHide this!Advertise here!
