Roender's FC-100 prototype and builder's thread
Old 18th January 2013, 07:10 PM   #651
miepa is offline miepa  Austria
Originally Posted by Telstar View Post
I did another search on Mouser up to 2.5 ohm, and still nothing available. I had to up the power to 1W to find something.
If you can/like mount vertical there are a few that could work.
This is the closest match:
CPF12R2100FKB14 Vishay/Dale | Mouser
Hope this could help u guys.
hmmm, then you maybe looked in the wrong place!
here you go: cmf552r Metal Film Resistors - Through Hole | Mouser
shows all CMF55 between 2-3Ohm which can be ordered at the moment at mouser!
Originally Posted by roender View Post
Anything between 2 and 3 ohm will be ok.
roender, what would be the "better" solution instead of the 2R2?
2 Ohm
or
2,87 Ohm
thank you.
Old 18th January 2013, 07:16 PM   #652
Telstar is offline Telstar  Italy
Ahem,
wasn't the resistor specified for half watt? You can go higher but not lower (it causes higher distortion, provided it doesn't burn).
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 18th January 2013, 07:18 PM   #653
Ahem,
CMF55 is half watt. look at the datasheet. it`s 0,5W @ 70 and 0,25W @120
when you compare them with other datasheets like other Vishay or PRP you see the all refer to 70
Old 22nd January 2013, 05:45 PM   #654
does anyone use BHC Aerovox Slit Foils in the FC-100 Backend?
Old 9th February 2013, 02:16 PM   #655
robingerhard is offline robingerhard  Austria
hi
Gerhard
Old 9th February 2013, 02:49 PM   #656
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
And, Gerhard: how does the FC-100 sound in your ears?
Best regards - Rudi_Ratlos
P.S.: I like your build (metal and wood) very much!
Old 9th February 2013, 08:44 PM   #657
atupi is offline atupi  Romania
Gerhard, you posted only thumbnails, i'm not able to see your beautiful amp.
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 9th February 2013, 10:05 PM   #658
Could someone help me and explain how to use the testing/matching circuit presented on Buiders manual Page 22 in order to measure Hfe and Vbe for:
2SC3423Y/2SA1360Y
MJE15034/MJE15035
NJL0281/0302
For To-92 transistors i have a DMM with hfe measuring capability.
Thanks!
Adrian
Old 10th February 2013, 08:15 AM   #659
Since I know that Gerhard visits this forum not very often, I will publish a photo in his place.
Old 10th February 2013, 08:16 AM   #660
Adrian, I will send you an EMail regarding your question in post #658.
Best regards - Rudi
Roender's FC-100 prototype and builder's threadHide this!Advertise here!
