#621 |
John is on the right way now, and I think that it won't take long until he posts: "Simply beautiful sound".
Best regards - Rudi P.S.: I love your pictures! Last edited by Rudi_Ratlos; 27th December 2012 at 04:09 PM. |
#622 |
Hi After sorting out one side with Rudi s guidance i started on the other side.
No problems works perfectly 36mv with 5 active tt diodes. ![]() The problem i had with r28 smoke stopped when i changed the input short from 2 wires to ground(alum plate) to using a croco clip as in pic . . next musicregards john |
#623 |
John, did you measure the DC-offset? How big is it?
Rudi |
#624 |
Hello Rudi No not yet but will advise you i have not forgot,,taken my time
cheers john |
#625 | |
Sheldon Last edited by Sheldon; 29th December 2012 at 12:03 PM. |
#626 |
... and another FC-100, of one of the GERMAN DIYers, working at first go.
The case is still temporary. Best regards - Rudi |
#627 |
Where does that nice r-core come from?
#628 |
That one looks like Chinese. In eu you can find from selectronic in France.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#629 |
Wow! Horizontal cooling fins. Cool. I mean hot.
#630 |
Hi Rudi, follow up Post #610.
I wish I could say the New Year started on a happy note, but I'm starting to think this amp only works in Germany ( joking of course). I measured the Vf's as best I could. The "hot" channel values varied from 430-450mV with the bypass on a 447mV one. The bias is steady at 36-38 mV, the DC offset is low at 1 mV but and the heat sink is hot at 60+C. However the "cool" channel values were higher (470-490mV) with the bypass on a 470mV one BUT one diode measured low at 386mV. So I bypassed it since I don't know what I'm doing and now the bias on this channel starts at 25-30 and just keeps increasing 35-40-45-50 no sign of leveling off even while tuning back the trim pot, so power off. If I don't bypass that one but another, all is okay bias at 38 mV offset <3 mV and heat sink stays cooler at 45C!!! This amp seems very touchy. Any ideas? Happy New Year to all. Jean |
