Roender's FC-100 prototype and builder's thread
Old 21st December 2012, 08:09 AM   #601
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Gentlemen, if you are still wondering, how to build your FC-100 case, I want to give you an inspiration - see attached images.
This is how one of the German DIYers did it.
Start with an ALU - bottom plate (300 x 380mm, 4mm thick) and 2 ALU - side plates (150 x 380mm, 6mm thick) and buy 8 ALU brackets.
Leave a 10 mm gap between the bottom and side plates for good air ventilation.
Connect the heatsinks of your choice on the outer side of the ALU side panels.
Best regards - Rudi_Ratlos
Old 21st December 2012, 08:34 AM   #602
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Rudi,
Nice brackets
Old 21st December 2012, 12:27 PM   #603
lucylu is offline lucylu  England
Default Testing
Hi I have tested both back-end power supplies ,work ok no problems but volts are +36.5 AND -36.7 ,,,,, +36.9 AND -36.8 at empty fuse holders are these to high or ok thanks john
Old 21st December 2012, 12:43 PM   #604
John: if no load is connected (fuse not inserted): your backend-PSU power rail-values are quite o.k.
Rudi
Old 24th December 2012, 07:48 AM   #605
Telstar is offline Telstar  Italy
Originally Posted by zsaudio View Post
I can not find any info about it on their web. Do you have a datasheet?
I found the datasheet:
http://www.linearsystems.com/datasheets/LSK489.pdf
It can be interesting to use in some other project.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 24th December 2012, 11:06 AM   #606
zsaudio is offline zsaudio  Europe
Hi Telstar,
thanks for the datasheet, i'll read it. It looks like it has lower Ciss but lower transconductance too than the sk170 for the first glance.
I WISH YOU ALL A MERRY CHRISTMAS
zsaudio
Old 24th December 2012, 11:58 AM   #607
jprco is offline jprco  Canada
Hi, Rudi.
Any thoughts on my posts #598/600???
Merry Xmas all and Happy 2013.
Jean
Old 24th December 2012, 12:38 PM   #608
The low ciss can suit my application where I don't want a low lowpass filter. Hopefully samples will be available from distributors soon.
Merry Chirstmas to you and hopefully Santa will have left for me the fc100 kit
Old 26th December 2012, 09:51 AM   #609
Default Adjustment
Well the time came to switch on and see if my hard work pays off,this is what i have on both pcb.
Switch on frontend only 2 x 34 ,shunt looks good all leds on except 2 red/green on front of backend.
switch frontend on 2x 25v all stays the same but bulb tester shines brightly and same two leds off meter reads 36mv
If i try to ajust pot r22(upwards) then bulb tester starts to dim and resistor r28 (10r) starts to smoke.
Switch off shunt bulb tester goes out and both leds red/green come on
After reading old posts see Rudi s post 186 looks similar. can anyone advise please regards john
Old 26th December 2012, 11:43 AM   #610
Jean,
when I built and adjusted my FC-100 (the real one, not the prototype!), I had similar "problems" as you have.
One channel (heatsink) remained "lukewarm", the other one got much warmer (allthough I was able to adjust it correctly as well).
I found the reason for this after some measurements: 5 of the internal TT-diodes had a Vf of approx. 510 - 530mV
and the 6th diode had a Vf of about 560mV.
I then bypassed the 560mV - TT-diode by a jumper - and: now both channels (heatsinks) maintain the same temperature.
So: please measure the Vf across all TT-diodes of the "hotter" channel and bypass the diode with the highest Vf.
Best regards - Rudi
Roender's FC-100 prototype and builder's threadHide this!Advertise here!
