Roender's FC-100 prototype and builder's thread - Page 57 - diyAudio
Old 28th November 2012, 03:20 PM   #561
lucylu is offline lucylu  England
Default Head hurts
Now i have the shunt transformer i decided to test both shunts that i made months ago ,negative works 37.8 but positive nothing zero volts then smell smoke switch off ,looks like r33 resistor burnt and led looks dead ,this happened to both shunts i have check and checked .can someone please advise
Rudi received resistors thank you
Old 28th November 2012, 04:48 PM   #562
meanman1964's Avatar
Can you post a pic of your shunt boards?
Old 28th November 2012, 05:13 PM   #563
I took my time,,,,the led and r33 removed thanks john
Old 28th November 2012, 06:06 PM   #564
AndrewT is online now AndrewT  Scotland
The Rudi shunt regulator boards are OK.
It must be an assembly error.
Well almost OK,
either omit the film caps across the diodes or substitute a cap + resistor in series for each cap location.
Don't invite oscillation of the supply due to stupidly inserting a cap with an unknown inductance !
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 5th December 2012, 07:49 PM   #565
jprco is offline jprco  Canada
Lucylu re. post #558.
Your photo's of the FC100 PCB's shows that the correction to the 1uf capacitor and 2 resistors connection suggested by Rudi has not been made.
Rudi: another question for you. What are the NFB points used for on the FC100? Are they used to measure something? I can't find a reference to their use.
Jean
Old 5th December 2012, 09:15 PM   #566
Rudi_Ratlos's Avatar
Jean, the abbreviation "NFB" stands for "Negative Feedback". A proportion of the output (speaker) signal is fed back to the input,
after being inverted.
The NFB is "just another track" (though a long one) and has nothing to do with measurement.
Best regards - Rudi
Old 6th December 2012, 01:22 AM   #567
Thanks, Rudi. So what do we do with these points? Leave them alone, jump them together permanently to enable negative feedback or join them to on/off switch so we can choose the dynamics??? Nothing in the guide or builder's manual that I can find on the subject. Are these there simply for more seasoned DIYer's to play with??
Old 6th December 2012, 04:35 AM   #568
Burnt psu...
Transistors in wrong locations is a possibility.
Gajanan Phadte
Old 6th December 2012, 07:50 AM   #569
Jean, on page 36 of the "FC-100 Builder's Guide" I have written:
After you have finished the Backend PSU, connect the NFB Takeoff point to the NFB -point in the frontend on the solder side of the board
(right red line on page 27) and the frontend GND (STARGND) with a "thick" solid wire (to achive a very low-impedance connection) with the
BACKEND-GND (the other red line on page 27).
Please read the manual carefully and follow the instructions on how to do the adjustment of the quiescent current / BIAS.
Best regards - Rudi_Ratlos
Old 6th December 2012, 11:09 AM   #570
Another that adopts a project and refuses to give it the time (to read the manual) the project deserves.
regards Andrew T.
Copyright 1999-2017 diyAudio
