Roender's FC-100 prototype and builder's thread
Old 6th April 2012, 10:32 PM   #401
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Default Matching the NJL transistors
... is not an easy job.
I have etched some small PCBs representing this schematics:
and measured a NJL0281DG.
As power supply I use a LAPTOP PSU rated at 15V/4A.
The results: the current that is flowing into the collector of the NJL is 160mA, the current flowing into its base is 2.49mA.
The resulting Hfe is 64.2, which is smaller than the documented minimum of 75 in the OnSemi datasheet.
The reason for this difference is that OnSemi does its measurements with a collector current of at least 500mA
and having a different VCE (5V), while my VCE is about 6V.
I cannot increase the collector current very much without risking the thermal death of transistor T1.
Nevertheless I think that this little PCB will help finding "matched" triples of NJL transistors.
Best regards - Rudi_Ratlos
Old 7th April 2012, 09:54 AM   #402
R.I.P.
voltage across T1 should not be a problem.
Try to set up your supply voltage such that T1 is dropping about 1.5V.
This will give a dissipation of 6W @ 4A. A decent heatsink will save this transistor.
If you adjust the base stopper of T2 to get your Vce to 5V then you can check both the base current and the Vbe at near your test values of 5Vce and 4A without risking any components.
If you want you can repeat these measurements at 2A and 1A.
regards Andrew T.
Old 7th April 2012, 10:21 AM   #403
I will try, Andrew.
I suppose that OnSemi measures the transistors at a lower supply-voltage: 10-12VDC.
I am lucky to have my LAPTOP power supply and will be able to adjust the supply voltage by means of a 7805.
Maybe I will be able to adjust to IC=500mA @ VCE = 5VDC.
Old 7th April 2012, 10:28 AM   #404
R.I.P.
add a 10r in series with R5. This becomes your base current measurement.
The 2k2 can be a switched resistor for different Ic values.
regards Andrew T.
Old 1st May 2012, 11:09 AM   #405
Since we have a public holiday in Germany today, I had some time and soldered the first PCB, a shunt-regulator board.
I am missing a heatsink for the negative rail as you can see.
(I will unsolder my prototype tonight - LoL.)
I connected a 1.8K resistor to the output giving a load of approx. 21 mA.
The transformer used has 2 x 35 VAC secondaries; this time I am using a 36V Zener diode.
The shunt works flawlessly.
Did I ever thank Mihai for developping this wonderful AMP?
If not - thank you, Mihai
Old 1st May 2012, 08:08 PM   #406
I have been asked if I am sure that the solder pins of the heatsinks that I am using (see attached image) are "electrically coupled"?
I am not sure, but when I measure the resistance between the 2 solder pins, my multimeter returns a value of 0 Ohm.
The datasheet does not reveal, if a connection between a solder pin and the body of the heatsink exists.
Does anybody know for sure?
Old 1st May 2012, 08:49 PM   #407
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
It all depends of the pins scratchs off some of the black surface but you need to know alu is a bad conductor for electricity
Old 1st May 2012, 09:01 PM   #408
evette is offline evette  Canada
Send a message via Yahoo to evette
Rudi 90% of all these heatsinks are made that way. Evette
Old 1st May 2012, 09:12 PM   #409
metal is offline metal  Jordan
metal's Avatar
I believe when these pins are inserted in the heatsink, even if there is some sort of coating (black color), it will be scratched away, these pins are thicker than the actual hole in the heatsink to make the assortment tight. AL is not that real bad conductor any way.
Old 1st May 2012, 09:23 PM   #410
Drop a screwdriver on you output transistors and you,ll find out how great a conductor it is. Evette
Roender's FC-100 prototype and builder's threadHide this!Advertise here!
