Roender's FC-100 prototype and builder's thread
Old 9th March 2012, 07:15 PM   #331
zsaudio is offline zsaudio  Europe
PS, Mihai i really like your amp. I'll do some thd test tomorrow then will start to hook up the other channel. Just can't wait for listen to it.
Best Regards,
zsaudio
Old 9th March 2012, 07:23 PM   #332
wtm111 is offline wtm111
zsaudio, Thanks for the measurements and details… they look great!
Old 9th March 2012, 07:32 PM   #333
roender is offline roender  Romania
roender's Avatar
Remove the output coil but let the input LP filter in place.
How fast is it (slew rate)?
I'm glad you like it from measuring POV but you'll like it more singing
Old 9th March 2012, 07:55 PM   #334
Hi Mihai,
output coil is removed now and input lowpass soldered (100pF).
Soundstage with Class A/AB amps
post 20 by Aksa interesting. I'll give it a try.
Best Regards,
zsaudio
Old 9th March 2012, 08:24 PM   #335
Lissajous at 100kHz only resistive load
100nF load added
zsaudio
Old 10th March 2012, 08:19 AM   #336
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
ZSAUDIO,
thank you for all your measurements and efforts to prove the performance and stability of this AMP /PCB. Great job!
I will now start and correct the slight flaws of the layout that I found during my build of the prototype:
- emitter resistor PADs being very small
- clearance / isolation ring in the middle of the PCB being very small
- increase the space around C18
- rename all the components' names to confirm to Mihai's convention
- increase the space between emitter resistors and the 4 caps in the middle of the PCB
- reconsider the functionality of the embedded PSU
If you found additional issues during your prototype-build: please tell me (per EMail).
I will now connect the AMP to a "better-quality- source" (CDP), but have to build an attenuator (I will finish and use
my lightspeed passive attenuator) first.
If Mihai's FC-100 keeps being so promising, I will open a group-buy for it in April.
I am looking forward to your listening impressions.
Best regards - Rudi_Ratlos
P.S. And - of course - I will write a "FC-100 Builder's Manual".
Old 10th March 2012, 05:49 PM   #337
I measured the THD1. I used my diyed 1kHz ultralow THD oscillator from Linear Tech LT1115 datasheet.
My spectrumanalyzer is an EMU 0404 USB a laptop win7 x64 software is Spectraplus 5.
Sorry for the 50Hz and sideband trashes but i did not take the time to tame them.
All measurements were done for 6R resistive load.
100mW
1W
10W
30W
Old 10th March 2012, 05:59 PM   #338
50W
Before clipping
and the sinus signal on the scope.
Sorry guys for the mess signals but i thinks it's enough to show the amp's THD1 performance.
I'd measure THD20 if i could but i do not have the right equipment.
I know THD20 would be more interesting.
The amp (only one channel) plays music on an average speaker.
So the judgement will be on my better speakers when the other channel will be finished.
zsaudio
Old 10th March 2012, 06:02 PM   #339
Again the sidebands comming from my measuring setup not from the amp!!!
zsaudio
Old 10th March 2012, 07:13 PM   #340
metal is offline metal  Jordan
metal's Avatar
this amp is really good, thank you very much zsaudiuo, you made my day :- )
Roender's FC-100 prototype and builder's threadHide this!Advertise here!
