Roender's FC-100 prototype and builder's thread
Old 8th March 2012, 06:51 PM   #311
roender is offline roender  Romania
roender's Avatar
Good work Rudi!
Anyway ... let's hope that others NJL power transistors didn't come with the wrong internal schottky diode.
Old 8th March 2012, 06:53 PM   #312
zsaudio is offline zsaudio  Europe
One board switched on.
I use 5 TC diodes. I can set my bias from about 6mV up to the desired 18-21mV across 0,1R Re. I did not watch for the max current.
My backend PSU voltage is +/-30V DC because i do not have any trafo with 225V secondaries.
Output DC offset is about 0,1-0,15 mV
I'll do more test tomorrow.
zsaudio
Old 8th March 2012, 06:58 PM   #313
hallcon83 is offline hallcon83  United States
Hi Guys, I just found your thread ! Is it to late to get in on the group buy? Kind regards, dean
Old 8th March 2012, 07:38 PM   #314
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
if i recall correctly, rudi and zsaudio were going to "beat the prototypes to death" first before opening up for group buy.
looks like the beatings are going well ...
mlloyd1
Old 8th March 2012, 07:54 PM   #315
The project was started by Rudi and Metal.
I think when the boards work well built by different people successfully it will be offered as GB.
I'm still testing, will report back.
zsaudio
Old 8th March 2012, 09:01 PM   #316
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
@PeterLeest
I tested with a 1 KHz square-wave as well.
I did not see any oscillation on the scope. No problem.
A very interesting feature of this AMP is: no "crack", while turning power-on and no hiss or "SCHSSsssssss" during power-off.
Carlos' DX AMPs (the ones that I built) and Michael Bittner's SYMASYM have at least the "SCHSSsssssss" during power-off.
I am looking forward to ZSAUDIO's experiences with this AMP.
Congratulations, Zsolt, to your build!
Best regards - Rudi_Ratlos
Old 8th March 2012, 09:08 PM   #317
wtm111 is offline wtm111
Yes, pretty interesting, post 725, gives some ideas on the "thump" start up.
RMI-FC100, a single stage audio power amplifier
Old 9th March 2012, 05:51 AM   #318
roender's Avatar
Originally Posted by Rudi_Ratlos View Post
@PeterLeest
That's nothing compared with how it sound
Guys, I'll bet this will be your ultimate amplifier. Look after better speakers, sources and forget power amp because this is almost a wire with gain :-)
Old 9th March 2012, 11:40 AM   #319
Rudi,
are you still set up with output Re=0r22?
and still with Ibias=2.3mA?
Sort these and then compare to the Roender original before you blame anything else.
regards Andrew T.
Old 9th March 2012, 11:52 AM   #320
Yes, Andrew,
I still use my 0R22 emitter resistors and I did not change anything to get a lower Ivas.
I measured an Ivas current of 2.3 mA some days ago.
Best regards - Rudi
Roender's FC-100 prototype and builder's threadHide this!Advertise here!
Copyright ©1999-2017 diyAudio
