Roender's FC-100 prototype and builder's thread
Old 12th February 2012, 10:25 PM   #141
wendell c is offline wendell c  United States
Nice I would be very interested when these are finalized, I read up on the original FC-100 amp last year and put it on my to do list.
Old 14th February 2012, 12:59 PM   #142
chchyong89 is offline chchyong89  Malaysia
Send a message via MSN to chchyong89
Can you put my name in the list for a set when its done?
Old 14th February 2012, 01:31 PM   #143
metal is offline metal  Jordan
metal's Avatar
You can actually put your name here:
https://docs.google.com/spreadsheet/...xVUQ2clE#gid=0
Old 14th February 2012, 02:32 PM   #144
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
@chchyong89:
I have started doing the build today (see attached image) and will go on matching the small transistors (BC550C, BC560C, ...,
the HFe matching will be done using my DMM) and solder them tomorrow.
I have begun with the resistors, and as you can see: I am using standard metal resistors.
I will use "standard" components throughout this build, but I will use carefully matched input transistors (LSK170)
and closely (< 5% HFe, VBe) matched output transistors.
I will then try and prepare the heatsink.
This will be the biggest challenge for me: I am not a craftsman at all!
Take a look at this thread once a week or so.
This is no longer a "group-buy thread" currently.
I would like and call it: "My FC-100 prototype building blog".
If I succeed with this AMP (designed by Mihai, the PCB being layouted by METAL and me), this thread will contain
all the information necessary to do it yourself.
I will keep you informed about my progress.
Best regards - Rudi_Ratlos
Old 14th February 2012, 03:27 PM   #145
I have a small heatsink with height of 10cm, can I know the height/width of the board inclusive the NJL0302D installed?
edited
Old 14th February 2012, 08:44 PM   #146
DaveM is offline DaveM  United States
DaveM's Avatar
I would likely be game for building a prototype. I am fresh to this thread, so I will have some catch up reading to do. What are the specs for the needed transformer?
Old 15th February 2012, 07:15 AM   #147
@chchyong89:
The size of the heatsink needs to be bigger than 104 x 191 mm (see the attached image of the drill-master).
A heatsink with a height of 100 mm may be a little bit short.
I will use an old 100 mm heatsink for the prototype as well.
I will not yet use the heatsink shown in post #140; I have to obtain some experience drilling and mounting the transistors beneath the PCB first.
@Dave:
Mihai's FC-100 AMP needs a transformer with 2 x 25 VAC secondaries for the backend and a small transformer with 2 x 34 VAC secondaries for the frontend.
Mihai designed a shunt-regulator at +/-39 VDC to power the frontend.
I have layouted this shunt-regulator as well (shown in post #130), but I am still waiting for the prototype to be etched.
If you would like building a prototype as well: my offer #2 is still to have.
Best regards - Rudi
Old 15th February 2012, 10:24 AM   #148
Originally Posted by Rudi_Ratlos View Post
@chchyong89:
Best regards - Rudi
I found this casing from china website and it cost roughly 60usd. I love it very much but the size is very compact @ 220*85*300mm(inner). I wish to build this amplifier and fit into a small casing that can do everything for me without wasting space.
I think I will try to draw a PCB to fit into the case by using 1/8 resistors or 0805 SMD.
I have checked the Nover 10,000uF/63v and 1,000uF/63V, the diameter is relatively small at just 30mm and 16mm diameters respectively.
Hope Mihai would give me a permit to do that.
Old 15th February 2012, 04:43 PM   #149
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Rudi,recieved the boards today.
Old 15th February 2012, 09:39 PM   #150
PeterLeest is offline PeterLeest  Singapore
Hi Rudi, paypal money sent for 2nd offer of the test board and components.
Roender's FC-100 prototype and builder's threadHide this!Advertise here!
