Roender's FC-100 prototype and builder's thread - Page 10 - diyAudio
Old 23rd December 2011, 06:35 PM   #91
I cannot follow any of your logic.
If the schematic shows +-34Vdc, what do you expect the maximum signal available at the speaker terminals when driving 8r0 with a sinewave test signal?
I would expect <30Vpk and more probably <26Vpk.
Can you really expect a passive heatsink of ~ 3"high by 3"wide by 1"deep (15mm fins) to dissipate at the rate of 0.8C/W?
I see part of my error in reading your dimensions.
25 = 1", NO!
25 = centimetres !!!
250 = ~10"
25 = ~1"
25cm = ~ 10"
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd December 2011, 06:40 PM   #92
That is exactly my question. You are not being helpful.
Are you blind? The heat sink is 10" long. Take the time to look at the diagram before you open your mouth.
/Mason
Old 24th December 2011, 05:58 AM   #93
Default heat sinks...
Originally Posted by greenm01 View Post
Are you blind? The heat sink is 10" long. Take the time to look at the diagram before you open your mouth./Mason
I apologize for being harsh; I believe we may simply have a breakdown in communication. Happy Holidays and good will!
I ran the LTSpice simulation, located in the original FC-100 thread, and found the following max power outputs (before output sine started clipping)
  1. 60W @ 8 ohms
  2. 120W @ 4 ohms
Using the approximation that the class AB output stage will dissipate ~46% (via Bob Cordell's text, page 104) of max rated power as heat, at 1/3 output power (assuming a 60C max heat sink temperature @ 25C ambient), I get the following thermal resistance (smaller requires larger sinks):
  1. 1.2 C/W for 8 ohm loads
  2. 0.6 C/W for 4 ohm loads
It never hurts to overcompensate thermally with larger heat sinks, but when space and budget are serious considerations I believe these are realistic numbers. I only plan on using 8 ohm speakers, so my heat sinks and chassis will not have to be very big.
Attached is the LTSpice simulation for your reference.
/Mason
Old 24th December 2011, 12:53 PM   #94
Rudi_Ratlos's Avatar
Gentlemen,
while I am waiting for Santa Claus to climb down the chimney, I like and show you a picture of METAL's and my progress:
http://www.abload.de/img/both_1m7j9e.png
We will offer you these 2 PCBs:
1) the PSU (on the bottom of the picture; its size is: 170 x 85mm)
2) the AMP (on top of it; its size is 143 x 73mm)
The PSU includes:
1) the backend PSU
2) the frontend PSU (Mihai's shunt regulator)
We still have to settle upon several questions:
1) Where to combine the Backend-Power(VCC and VDD) - GND planes? On the AMP PCB, on the PSU PCB?
2) Where / how to connect the Backend-Power - GND to the Frontend-Power GND? On the AMP PCB, on the PSU PCB?
3) Where to connect Speaker's Return? To the AMP PCB, to the PSU PCB?
4) Where / how to connect the different GND-planes to the Power Earth / Safety - STARGROUND?
When these questions are answered, we are done.
I wish you all a happy Christmas - Rudi_Ratlos
Old 24th December 2011, 04:03 PM   #95
Do you happen to have a schematic of the PSU?
BTW, excellent job. I'm very much looking forward to having these boards in my hands!
/Mason
Old 24th December 2011, 07:19 PM   #96
Bob03 is offline Bob03  Canada
Bob03's Avatar
Default Capacitor holes
Hi Rudi,
To make your PSU boards more universal, could you please implement support for different capacitor pin-outs (like Peter Daniel on his PSU board).
F5 pcb group buy...
I wish you all a happy Christmas,
Bob03
Old 26th December 2011, 10:53 AM   #97
zdr is online now zdr  Belgium
zdr's Avatar
Rudi, you still have two bjts near 470uF facing the same direction instead each other.
Old 26th December 2011, 11:57 AM   #98
Ferrari is offline Ferrari  Netherlands
zdr, make yourself a fresh cup of coffee, sit back, take a close look at the photo's on post #3, #4 and
the schematic on post #8 of Roender's amp thread and you will find the answer yourself.
Rudy has also answered your question in post #61 of this thread.
Old 26th December 2011, 12:12 PM   #99
Ferrari Zdr,
you have confused me.
Should the BJTs be facing each other or facing away?
How were they on the Roender PCB?
Is Rudy's PCB the same or different?
regards Andrew T.
Old 26th December 2011, 12:13 PM   #100
zdr's Avatar
You are referencing very early stage of Mihai's thread, lets take a look at some newer photos together. Am I missing something here?
Copyright 1999-2017 diyAudio
